Results 1 to 10 of 20
July 30th, 2013 10:35 PM #1
Hello mga tsikoters..
question lang..normal lang ba kung medyo umiinit yung motor pump namin pag naka andar?
tolerable naman yung init niya yung tipong pwede mopa hawakan..
TIA
July 30th, 2013 10:38 PM #2
July 30th, 2013 11:13 PM #3
umiinit naman talaga yan dahil motor yan pero kung manipis lang yung higop niya ng tubig, mas mainit siya kesa normal.
ingat ka lang baka maya wala na palang nahihigop na tubig, masisira o masusunog yang pump mo.
siempre pag nasunog pump mo may tendency na sumabog
bahay t*e mo kasi wala ka ng
panghugas dahil diyan nakasalalay tubig niyo.
hth
July 30th, 2013 11:17 PM #4
umiinit naman talaga ang motor pump. you could check the current reading to see if your motor pump is working normally.
July 31st, 2013 01:32 PM #5
yung current (Ampere) reading should be within the specs stated sa motor.
- Sep 2008
- 742
July 31st, 2013 05:09 PM #6You need to take ampere reading. It should within range based on the nameplate of the motor. Otherwise, you need to find the fault.
July 31st, 2013 07:02 PM #7
checking the ampere reading is the easiest way to detect if the motor pump is working properly. other methods include infrared thermography and simply use your ear to hear any unusual noise emitted by the motor.
July 31st, 2013 08:21 PM #8
Check mo din yung fan sa likod ng motor baka naman maluwag na at di na umiikot ng tama. O baka barado yung louvre ng fan. Pwede din malapit na bumigay ang bearing, so check for bearing noise. Or, sadyang low quality yung motor - loose windings lead to a hot motor. Ano make ba. Madami cheap china water pumps, 3 years lang sunog na windings o sabog ang bearing.
Tsikot Member Rank 4
- 2,719
July 31st, 2013 11:19 PM #9
July 31st, 2013 11:21 PM #10
OT:
pwede ba gamitin ung water pump as diesel pump? if no, saan ba makakabili and recommended brand for a diesel pump na maliit lang let say 1.5HP.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
