Results 1 to 20 of 20
    Aug 2006
    Hello mga tsikoters..
    question lang..normal lang ba kung medyo umiinit yung motor pump namin pag naka andar?
    tolerable naman yung init niya yung tipong pwede mopa hawakan..
    TIA
    Feb 2009
    Quote Originally Posted by earthlyken View Post
    TIA
    hehehehe slightly dyslexic
    water pump motor ng ano?
    Sep 2009
    umiinit naman talaga yan dahil motor yan pero kung manipis lang yung higop niya ng tubig, mas mainit siya kesa normal.
    ingat ka lang baka maya wala na palang nahihigop na tubig, masisira o masusunog yang pump mo.
    siempre pag nasunog pump mo may tendency na sumabog
    bahay t*e mo kasi wala ka ng
    panghugas dahil diyan nakasalalay tubig niyo.
    hth
    Oct 2011
    umiinit naman talaga ang motor pump. you could check the current reading to see if your motor pump is working normally.
    Oct 2009
    yung current (Ampere) reading should be within the specs stated sa motor.
    Sep 2008
    You need to take ampere reading. It should within range based on the nameplate of the motor. Otherwise, you need to find the fault.
    Oct 2011
    checking the ampere reading is the easiest way to detect if the motor pump is working properly. other methods include infrared thermography and simply use your ear to hear any unusual noise emitted by the motor.
    Quote Originally Posted by holdencaulfield View Post
    hindi ba baliktad sir? kapag walang mahigop na tubig ang pump, di ba walang load yung motor/pump? kapag walang load ang motor, less running current, hence lesser temperature rise?
    Sep 2009
    Quote Originally Posted by kinyo View Post
    di ba parang coolant ng pump ang tubig?
    sa mga powerhead ko sa aquarium pag inaangat ko sa tubig, umiinit.
    air-cooled lang yung motor ng water pump na pambahay ... madalas may fan sa likod
    Oct 2011
    hindi naman makita ang fan sealed type kasi.
    meron shroud yung fan ... madali tanggalin, sungkitin lang
    yung water pump namin hindi umiinit pag humihigop ng tubig tabi lang kasi ng lababo namin minsan kasi hinahawakan ko yung motor wala talagang init pinapalamig ng tubig na hinihigop niya. BTW made in Italy yun mahigit sampung taon ng gamit namin di pa nabubuksan.
    Sep 2009
    tatlong beses nakong nasunugan ng pump dahil walang nahigop na tubig. yung dalawa dito sa bahay, yung isa sa dati naming refilling station. di kakayanin ng fan lang ang cooling ng motor niyan. nakita mo naman bakal ang kaha niyan.
    subukan mo lang na gawin sa motor mo mga 5 minutes na walang tubig mangangamoy yan chong. yung dalawa kong nasunog binilinan ko yung mga katulong na huwag isisindi dahil may gagawin sa tubo. eh sinindi, nangamoy na di pa pinatay hanggang..... sunog!
    pinalampas ko yung una pero yung pangalawa hindi na dahil sinabihan ko sila na isasaksak ko na lang yung mga puw3t nila sa tubo pamalit ng nasirang pump.
    kaliwat kanan ang bentahan ng ganiyan dito samen at bilin naman nila palagi na huwag pababayaan na walang tubig para di masira.
    Sep 2009
    anong brand ng water pump mo sir?
    yung una ko saer, tapos pedrollo tapos italy kuno.
    May 2012
    lahat ng water pump, medyo iinit depende sa dami ng tao sa bahay. kung 1hp ang motor, 3.8amps ang current(run). Syempre, ang start current ay 10amps+,
    kung walang hinihigop na tubig, less than 3amp, dahil tuloytuloy ang andar(walang pressure sa tanke), sunog ang motor.
    I've seen motors na queer ang performance. the problem was in the start capacitor. Bumaba ang capacitance from 10ufd down to 7ufd. i used a HP RLC bridge to determine this fault. Usually, a motor should run for 10 minutes before the pressure switch would go "off'. 7-8 minutes is the average. if the motor does not turn off after a long time, walang hinihigop na tubig. Iswitch-off agad,
    Oct 2011
    usually water pump na continues ang takbo, advisable na duplex type ang gamitin.
Water Motor pump umiinit
