Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Aug 2006
    Hello mga tsikoters..
    question lang..normal lang ba kung medyo umiinit yung motor pump namin pag naka andar?
    tolerable naman yung init niya yung tipong pwede mopa hawakan..
    TIA
    Feb 2009
    Quote Originally Posted by earthlyken View Post
    TIA
    hehehehe slightly dyslexic
    water pump motor ng ano?
    Sep 2009
    umiinit naman talaga yan dahil motor yan pero kung manipis lang yung higop niya ng tubig, mas mainit siya kesa normal.
    ingat ka lang baka maya wala na palang nahihigop na tubig, masisira o masusunog yang pump mo.
    siempre pag nasunog pump mo may tendency na sumabog
    bahay t*e mo kasi wala ka ng
    panghugas dahil diyan nakasalalay tubig niyo.
    hth
    Oct 2011
    umiinit naman talaga ang motor pump. you could check the current reading to see if your motor pump is working normally.
    Oct 2009
    yung current (Ampere) reading should be within the specs stated sa motor.
    Sep 2008
    You need to take ampere reading. It should within range based on the nameplate of the motor. Otherwise, you need to find the fault.
    Oct 2011
    checking the ampere reading is the easiest way to detect if the motor pump is working properly. other methods include infrared thermography and simply use your ear to hear any unusual noise emitted by the motor.
    Check mo din yung fan sa likod ng motor baka naman maluwag na at di na umiikot ng tama. O baka barado yung louvre ng fan. Pwede din malapit na bumigay ang bearing, so check for bearing noise. Or, sadyang low quality yung motor - loose windings lead to a hot motor. Ano make ba. Madami cheap china water pumps, 3 years lang sunog na windings o sabog ang bearing.
    Quote Originally Posted by holdencaulfield View Post
    hindi ba baliktad sir? kapag walang mahigop na tubig ang pump, di ba walang load yung motor/pump? kapag walang load ang motor, less running current, hence lesser temperature rise?
    Oct 2011
    OT:
    pwede ba gamitin ung water pump as diesel pump? if no, saan ba makakabili and recommended brand for a diesel pump na maliit lang let say 1.5HP.
Water Motor pump umiinit
