Wow exciting times bro. When is the move in date.....
put a clothes rack in the balcony, smack in the middle. for sure overnight lang tuyo na mga damit ninyo lalo na if both ac is working overnight.
The 2nd compressor could've been placed on top of the 1st one using a frame ... Additional balcony space ...
Good choice. Future Daikin user here (dsmart and smart elite). 3 weeks ng installed still waiting for move-in.
I went with the setup na magkapatong yung outdoor unit tapos same drain nalang sila. Yung connection ng pvc pipe was right after the bottom compressor
I'm happy with how my contractor cleaned up the installation of my aircons.
Hmmm, on the 2nd pic, it seems they built the cover around the AC. Come trouble time, it would take more work to remove & repair. The framework of false beam concealing the pipes should've been done 1st w/ lines pre-laid & the AC unit mounted onto the painted surface last.
I didn't quite understand what you proposed. What they did was install the aircon pipes then cover it up with plaster or plywood or whatever it is thst they used. Basta if there's a problem then bakbakin lang yung wall then fix whatever's leaking then make a new false pillar/ceiling again.
Form > function for me. Ayoko ng industrial look na nakalabas yung pipes. Basta utos ko was to have the aircons installed and make sure the pipes aren't an eyesore. They delivered on that request so I'm fine.
Labas lang sa pinag usapan
Hindi ka ba marunong mag tagalog sir travajante?
Travajante is there any advantage in using a 2 tonner? The one that looks like a refSome homes still use that kasi or that should be replaced na?
We use this type of PU foam spray for the wood jamb-concrete gaps. Good insulator & very stable adhesive, yet easy to remove. It's multi-purpose.
^ That and those GreatStuff brand available at Ace and Handyman even online.
If not available i'd use the generik silicon sealant less than P50 from the hardware, just buy a good caulking gun i bet that should last forever in your hole/gap sealing needs. Downside of silicon is the vinegar/ammonium smell while curing.
