Results 1 to 10 of 31
Threaded View
    Jul 2006
    You should check your nuts at least once a week... hmmm... I think I should go check mine.
    There's also the factor of old, rusty lugs snapping off... malamang ganyan yung nangyari sa isa, then over time, the others wore down because of the unbalanced vibrations until they all gave way, catastrophically.
    Proofread man...iba pagkaintindi ko
    Here in the US marami ako nakikita na tire blow-outs. Bakit? Paiba-iba kasi temperature dati ti was really hot so the tires were probably overinflated. Then it became much cooler, so now the tires are underinflated (assuming they do not know how to adjust the pressures). I often see tire treads on the freeway minsan iniiwasan ko na lang then I see the disabled vehicle on the side of the road with the rim badly scraped sans the tires.
a tire almost hit me....
