Page 5 of 5 FirstFirst 12345
Results 81 to 94 of 94
    #81
    10 feet? amateur lang un AFAIK., pero ang alam ko sa PBA and FIBA is 12 FEET.
    "Each basket ring shall be securely attached to the backboard with its upper edge 10’ above and parallel to the floor and equidistant from the vertical edges of the board.The nearest point of the inside edge of the ring shall be 6” from the plane of the face of the board. The ring shall be painted orange."
    NBA yan. generally, its the same.. sobra naman discrepancy ng 2 feet for amateur and pro.
    Apr 2006
    #82
    sabi ko na eh 10feet din sa amateur yata 91/2 or 9feet ksi di ako makapaniwala na dinadak dakan ni nate robinson ang 12feet na ring thnx mga papi sa pag sagot.
    Oct 2003
    #83
    Quote Originally Posted by jasprit View Post
    any tips po on how to improve my leeping ability mga exercises po kahit ano po. thnx in advance.
    In college, we use garter as our jumping equipment. Set it up criss cross for 3-4 ft. adjust it as your leaping ability increases. You can use ankle weights/belt weights with it.
    Other method we use is tapping the base of the board 30 times with left hand, 30 times with right hand, and 20 times with both hands. That will improve your jumping consistency(reaction) and improve your calf and leg muscles.
    Using the edge of the stairs for tip toeing to flex your calves. 50 reps in 5 sets every other day as an added exercise.
    I hope this helps.
    #84
    slightly OT, since na-cover na natin lahat ng exercise and techniques
    let's not neglect the proper agility and endurance drills, because without those you'll be a great high jumper but shitty basketball leaper.
    also while we're at it, i hope you're focusing more on shooting, ballhandling and even rebounding/positioning drills more so than leaping. that's what's going to get you the PT. awesome leaping ability is good for a few aaahs in the pregame layup line, but you want to make sure you get a chance to use it in the game ;)
    Jan 1970
    #85
    push a car on a backward position for ten minutes.
    same backward position, try to lift the car (kinda like pressing your leg muscle to its limits).
    May 2005
    #86
    Quote Originally Posted by M54 Powered View Post
    sirM54,mukhang di ka lang expert sa Fantasy league,,
    pati mga trick sa actual game .kabisado mo ..
    ikaw na gawin na coach at ako enforcer mo sa team.hehehe
    jasprit :dami nagadvice sa iyo pag hindi ka pa naman lumipad sa laro mo niyan
    mukhang pinaghahandaan mo ang interbarangay sa inyo..hehehe
    Aug 2006
    #87
    tsaka nga pala., sumali din ako sa vollyball team nung h.s. ako., na walang ginawa kung hindi 2malong talon., tsaka natuto ako maglaro sa ere kaya mas masarap magdunk.,
    May 2005
    #88
    iyon yata ang training ng mga Volleyball player ,kung paano pataasin tumalon ,,kay adami din ako nakikita mga player ng volleyball .kung hindi lundagin ang ring ay mag dunk gamit ang bola ng volleyball,,
    sayang ang iba player kasi ay bading
    #89
    boeing, player-coach na lang para may license magbwakaw :bwahaha:
    Aug 2006
    #90
    praktis name nun,. puro long jump., then leaping., dapat ma-bend mo ung knee mo patalikod na dapat tumama sa butt mo, bago ka mag-spike., harsh training., dahil paguwi mo sa bahay., kain tulog ka na agad., pero na-bear ko naman un ganun training., iwish i can do it again.,
    Apr 2006
    #91
    hirap ng training nyo tsong sakit nyan sa binti. Tama si boss M54 leaping is not every thing mas maganda i practice ang post up moves at hook shot 4or5 ksi laro ko how i wish na ang laro ko ay 1or2 sayang sinanay ksi ako maging center.
    Aug 2006
    #92
    and praktis tha what tell call pro-moves., pwede naman un., pagnaglalaro ako sa skul namen., i play the 1-2 spot., while sa liga d2 sa village namen nasa 4-5 naman., so advantage un vise versa kase, as guard na me pro-moves as center, pwede at kaya mo postehan ung defender mo., even at fastbreak me option ka na go for speed or go hard to the basket,. pag sa liga naman namen pag nasa 4-5 spot ako., me super advantage kc, pag binigyan nila ako ng space, pwede ko sila tirahan, pagdinikitan naman nila ako pwede ko sila iwanan., simple as that pero at first nahirapan ako mag-adjust, pero since sanay na kac yearly ung mga tournament, aun sanay na,. kahit anung position nalalaruan ko., so big development and avantage as a big man to shoot from the outside and a guard who can work at the post...
    #93
    jasprit, practice ka na lang ng outside shooting and ballhandling on your own time. sarap na laro mo parang Lamar Odom/Shawn Marion
    i learned to play ball here in the US, where at 6ft praktis ko na maige ang larong PG. tapos tumira ako for awhile sa Pilipinas pinag-centro ako :hihihi: it's a huge matchup problem...either drive past or step out against the bigs, and take the guards to the block :evil:
    yun nga lang wag kang tamad mag-rebound kundi sisigawan ka ni coach
    Nov 2006
    #94
    mahirap ang mataas tumalon.. malaki ang risk na mapilayan ka.. ang taas pa nman ng panggagalingan m tapos pag naapilok ka, disgrasya yan
Tips po [to improve leaping ability]
