Results 1 to 10 of 2105
January 12th, 2020 04:18 PM #1
Taal alert level 4 up after phreatic eruption >> Manila Bulletin News
January 12th, 2020 09:55 PM #2
From a Viber thread...
zero viz nuvali area.avoid CALAXand SLEX at least from binan to sta rosa.hirap mag drive basta basta na lang may humihinto as daan kahit Expressway lalo yung walang tubig ang windshield wiper.better uf you dont drive coming to or from these areas.keep safe everyone.
January 12th, 2020 10:17 PM #4
January 12th, 2020 10:28 PM #5
- Dec 2019
- 97
January 12th, 2020 10:05 PM #7To our dear Toyota customers:
Due to the recent ashfall from Taal Volcano, please be advised of the following immediate measures to protect your vehicle/s :
1. Please wash your vehicles with pressurized water to remove ash from the vehicle's body, but please do not wipe the vehicle while spraying water to avoid scratches on the vehicle's body
2. Please repeat if vehicle continues to be covered with ashfall
3. If engine room is affected, please bring your vehicle to your nearest Toyota dealer for proper engine cleaning.
Please also protect yourself from the ashfall while cleaning your vehicle by wearing protective gear like raincoat and mask.
Please contact our dealer if you have questions.
Thank you
- Dec 2019
- 97
January 12th, 2020 10:07 PM #8Don't use aircon daw
Due to the recent ongoing ashfall from Taal Volcano please be advised of the following measures to protect your airconditioning system:
If you experience heavy ash fall, kindly refrain from using your Split type airconditioner and window type airconditioners.
Continued use with heavy ashfall will result in the clogging of the outdoor condenser coil, which in turn will cause overheating of the compressor and overall airconditioning system.
Should you really need to use your Air Conditioning units, kindly be advised to wait until the ashfall decreases, then clean the area where your condenser is located before you resume air conditioner operation.
January 12th, 2020 10:42 PM #9
Huhuhu pano na flight ko sa 14 pabalik ng pinas, hope the eruption will settle down by tomorrow.
- 54,290
Are they on track to surpass last year's sales?
Car Sales Data (2025)
