Results 1 to 7 of 7
- Jun 2005
- 28
May 13th, 2006 10:16 PM #1mga sirs, question lang po about globe. i'm here at nj for almost a week now. wifey called naubos load ko. naka reload po ako. but now i cannot access cingular phone to reload again. meron naman po cellsite ang cingular from where i am staying. thnks in advance. and roaming activation ko po is 30 days.
May 13th, 2006 11:24 PM #2
na-deactivate ka kasi below minimum na yung load mo. dapat kasi before bumaba sa minimum (p100 yata) pa-eload ka na agad para di ka ma-deactivate. ang alam ko sa globe pag deactivated ka kasi below minimum load e di na maactivate ulit. pero try mo pa din.
roaming inquiries toll free *131*6327301212# using your cellphone.
to reload *123*+call card no+PIN+# (don't key in the "+")
to check balanc *123#
to activate roaming (but this only works in the phil) text to 2884 "GROAM ON MM/DD/2006 XX", where XX = no of days for roaming, normally 30.
to extend roaming text to 2884 "GROAM EXTEND XX"
pwede mo din patawagan sa misis mo yung globe at ipa-activate nya ulit roaming mo. nagawa ko na yan dati nung hindi pa pde i-text lang ang extension ng roaming.
May 13th, 2006 11:28 PM #3
try mo smart roaming, eto gamit halos lahat sa taiwan also me kasi nakakareceive pa rin ng text kahit la na load...
May 13th, 2006 11:32 PM #4
isa pa, if you are planning to use the hotel phones instead because you can not reactivate your roaming anymore, DON'T! laki ng bayad sa long distance calls, kahit na may discount call cards ka na mabili. instead of buying call cards or paying astronomical intl phones rates at the hotel, just buy yourself a cheap cell phone sa wallmart. $70 ok na yun, kesa magbayad ka ng $200 or more for using the hotel phone. tapos pag uwi mo sa pinas e di reserve phone mo na lang kahit pangit yung cheap phone.
May 13th, 2006 11:36 PM #5
Originally Posted by radiazone
May 13th, 2006 11:42 PM #6
baka may pinoy store jan, cgurado may activated na roaming... just maybe...
- Jun 2005
- 28
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
