Page 21 of 48 FirstFirst ... 1117181920212223242531 ... LastLast
Results 201 to 210 of 473
    #201
    Also had this issue ... google was not much help ... the tide powder used to have a free scooper which can be used as measurement ... then they stopped providing it ... so many scooper sizes ...
    in the olden days, the instructions did not use scoops. they used dakots (using the hand).
    #202
    Yeah, but then you'd have to count the clothes every time you do laundry ... there are big ones, small ones and tiny ones ... so just bought a scale and weighed the clothes ...
    we bought a digital bathroom scale recently. 800 bucks.
    it was sensitive to within 100 grams.
    nakaka-aliw.
    even the weight change before and after jingling...
    i am sure it can weigh one's weight of clothes for laundrying.
    #203
    Go liquid detergent. Lesser residual deposits Longer machine cleaning & maintenance interval....esp w/ hard water.
    #204
    Yes, this is the better thing to do.
    Jan 2016
    #205
    Yeah, just have to finish the 10 kg bag I just bought [emoji75]
    #206
    how does one know, it's time to clean the machine?
    Jan 2016
    #207
    Doc, the newer ones have indicators.
    #208
    and those who don't?
    Jan 2009
    #209
    Like cars, they have a manual that has instructions on how often and in what manner to clean the machine. It varies from one machine to another depending on what sort of filters they use. The most common I've seen are lint filters on the side of the top-load drums that should be cleaned every couple of months or so, depending on how heavily used it is.
    If the good book doesn't have that information, you will be able to tell by the looks of the drum if there are deposit build-ups that you need to worry about. In other words, if there are visible residue on the drum, there would be similar deposits on the tub. These deposits could chip off in large bits and either chew up the pump or water seal.
    Mar 2004
    #210
    Your clothes smell bad or moldy after washing ... by the time this happens, it's time to replace the washing machine ...
Please suggest washing machine.
