Results 21 to 23 of 23
April 27th, 2005 10:10 PM #21Originally Posted by doublea
Well..the thing is, even if it sends the data in a parallel configuration, it does it in a slower pace (compared to USB). And also, printer is an OUTPUT device...you dont really need anything to DOWNLOAD from the printer....in short - there's not much data to transmit from printer to PC....besides, it DOESN'T MAKE YOUR PRINTER PRINT FASTER. If you bought a printer that is rated * 25ppm - and both came in with Parallel and USB ports, and assuming they have the same spooling time (USB has faster spooling time though), your printer will still print the same speed whether you use parallel or USB.
April 27th, 2005 10:29 PM #22
I like USB kasi Plug N Play..kaso nga lang, nauubusan ako minsan ng USB ports kaya I opt to put the printer sa parallel. more of convenience and practicality for me. the slot's there kasi so why not use it?
high idle RPM at engine start
