Results 1 to 5 of 5
December 26th, 2007 12:48 PM #1
I'm planning to replace our 2 yr old tank to bigger capacity,went to home dpot and there are two designs first is yun nakatayo just like our present bestank second yun nakahiga is there any difference if nakatayo yun tank or yun nakahiga? I mean will the water pressure be affected pag yun nakahiga ang binili ko? or since it's overhead walang connection since gravity ang nagcocontrol
ano advantage and disadvantage ng nakahigang tank doon sa nakatayo?
Unregistered user
- Jun 2003
- 1,122
December 26th, 2007 04:23 PM #2there would be no difference...
the concern only is the available mounting space
horizontal would require more space while vertical lesser
in terms of pressure imho no difference
you can always install a pressure tank and motor if you want additional pressure
best tank brand is good
December 28th, 2007 08:57 AM #3
ilang gallons ang requirements? saka di ba merong stainless at plastic? I'm also planning to get one pero ang iniisip ko ay pano ko lalagyan ng switch yung overhead tank para auto shut off yung jet pump ko pag puno na yung overhead tank. My overhead tank will be located in the 4th floor while my pressure tank and motor is in the ground floor, 1 hp goulds ang gamit kong motor.
December 28th, 2007 06:07 PM #4
The rule of thumb for an overhead tank is that the lowest point of the tank should be higher than your highest shower. Since you're just replacing your old tank, and I assume you're using the same structure to support it, then you should be okay. You need to consider though, your structure in buying your replacement tank, as it may need modification with the new one.
5000:boom:
Unregistered user
- Jun 2003
- 1,122
December 29th, 2007 09:14 AM #5
Monk-owned R53
