Results 1 to 10 of 38
January 17th, 2022 11:03 AM #1
Planning to buy a multimeter / multitester ... need basic device to test for current / electricity ... can buy something more expensive for future-proof if price difference isn't that much ... only used occasionally (2-3 tines a year) ...
So far, found these two best sellers on Shopee ... an electrician mentioned something about an analog and digital model ...
https://shopee.ph/Ingco-Original-LCD...362.5058706694
https://shopee.ph/LCD-Digital-Multim...8-67bdd025c77a
Suggestions please ...
- 54,290
January 17th, 2022 11:24 AM #2they probably will fit the bill.
my main concern is the weight.
for me, the heavier, the nicer. para hindi nahahatak when working.
i have both the analog and digital variants. i personally like the analog, probably because it's what i was brought up on.
compared to yesterdecades,
today's multimeters are much cheaper, but just as accurate and reliable. even the cheap ones.
lucky, this new generation.
our old meters were sanwa and before that, an american brand i forget...Last edited by dr. d; January 17th, 2022 at 11:35 AM.
- Feb 2014
- 2,711
January 17th, 2022 12:54 PM #3【ANENG 】LCD Pocket Digital Multimeter Backlight AC/DC Automatic Portable Voltmeter | Lazada PH
this one looks a lot better. auto range. backlit. i think i'll buy this later even if i already have several slim multimetersmy favorite so far is UNI-T UT120
avoid the fat clunky ones w/ the noisy selector dial
don't get analog
get model that beeps on continuity
January 17th, 2022 02:56 PM #4
Yung binili ko sa Shopee na mura, nasira kaagad after less than 2 months
Ended up buying a "pricier" one found in the hardware store. Brand is Newstar. It is now 6 months and still working.
January 17th, 2022 03:07 PM #5
I'd go with a known brand, leads are protected in the case too.
https://shopee.ph/Sanwa-Cd800A-Digit...6-1bfc625b7e2e
January 17th, 2022 04:38 PM #6
You can't have enough...
I have two Sanwa analog multimeters (the other is in the office) and three DMMs.
99% of the time, I use the DMMs, as they have more functions than the Sanwa.
If you have an analog multimeter, always park the selector at the highest AC Voltage range (1,000 V AC in this model) when not in use. Don't leave it in resistance mode or current mode or you burn it up (lucky if you just pop the fuse) if you or someone else accidentally measure high voltage with it. You actually need those extra brain cells when using this. ;)
January 17th, 2022 04:44 PM #7
We only buy Fluke brand for our multimeters, clamp meters and thermal scanners. It is a bit expensive but very durable it will last you longer.
January 17th, 2022 04:49 PM #8
January 17th, 2022 04:52 PM #9
- Jan 2008
- 4,726
January 17th, 2022 04:59 PM #10ok yan sanwa.. may fluke naman sa shopee yung china version around 6k yata. orig na fluke for chinese market.
mas ok yung original na.. mahirap yan maliliit baka ma kuryente ka pa
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
