Results 1 to 10 of 32
- Oct 2009
- 2,271
August 2nd, 2016 03:51 PM #1naka experience naba kayo na magkaroon ng major problem ang mga sasakyan nyo.
sa akin kasi bumigay ung crankshaft pulley ng honda ko.tapos hindi na matanggal ung bolt sa gitna.ayun napilitang ibaba ang makina..
share nyo naman ung sa inyo..
August 2nd, 2016 04:58 PM #2
a few years back.
hyundai getz. nagbara yung oil circulation. kumatok makina, tinakbo ko pa. hanggang tumirik.
nung pinatow, pagbukas ng makina, wasak lahat. nabasak pati engine block.
napilitang magpa change engine.
eto na ata pinakamalupit na nangyari sa akin... the rest are simple suspension and mechanical problems.
- Oct 2009
- 2,271
August 2nd, 2016 05:23 PM #3
August 2nd, 2016 07:44 PM #4
August 2nd, 2016 08:21 PM #5
Siguro pinaka major eh yung panginginig ng makina which in turn eh squeaking yung fan belt. Dati ko na pinagawa sandali lang bumalik ulit. May parang Rubber na between the engine and the frame na hugis baso na kailangan palitan. Nakakahiya lang na every time I use the car na mainit ang panahon eh squeaking sya pero nawawala after a few meters. Pero pag ginamit naman na moist ang weather eh wala naman ingay.
August 2nd, 2016 10:28 PM #6
I recently had the power steering pump replaced on my 2006 Hyundai Sonata V6. It lasted 11 years and 190k miles (306k km). Plus, I was very abusive with the car on almost a daily basis. So, no complaints from me.
In fact, it's the first mechanical part I had to replace. The rest of the engine is still original.
The front right suspension has the most replacements probably because I hit a deer head on a few years ago.Last edited by Jun aka Pekto; August 2nd, 2016 at 10:32 PM.
August 2nd, 2016 11:47 PM #7
D-max 2004, 110K Km. Namamatayan ng makina. Tumirik last Sept. Hanggang ngayon hindi pa nahahanap ang problema!
First suspect, injection pump. Second suspect, filter sa loob ng gas tank. Ang sure, madumi ang diesel. Napakadaming nakuhang dumi sa loob ng gas tank at sa mga filters. Madumi talaga ang diesel sa Pinas! Petron and Shell lang nagkakarga.
- Apr 2016
- 211
August 3rd, 2016 06:51 AM #8Alternator, alternator, alternator :/
- 52,514
August 3rd, 2016 09:20 AM #9many years ago.
the metal springs of the rear seat, shorted the battery terminals under it.
ayun.. sunog yung sasakyan.
bulokswagen.Last edited by dr. d; August 3rd, 2016 at 09:22 AM.
August 3rd, 2016 10:20 AM #10
I bought 2nd hand aveo and my intermittent siya na biglang tumataas rpm up to 4k up and down so weird.. end up replacing the whole throttle body, after few months same problem came back,mechanic told me to replace the intake manifold yata yun but no parts available.. thanks god now aveo become normal rpm on its own na. Nobody knows what is the reason including casa here in sg.
Sent from my SM-N910G using Tsikot Forums mobile app
Traffic!
