Hi, anyone of you have an idea on what's the passing score for hydrocarbons ppm (HC ppm) in other countries? I googled around and their standards are quite high. The reason why I said this is because some cars got a an HC ppm score of 110 while I on the other hand got a score of 364 (btw, I'm not sure if it's also being measured here as HC ppm hehehe.. inakala ko lang kasi nasa hundreds ang bilang... Some "googled" tests ay nakalagay 1.x to 2.x so mababang number so I thought if it's in the hundreds ay parehas na ginagamit dito sa Pinas so just correct me if I'm wrong if hydrocarbons here are being measured as "HC ppm")
Btw, the 364 score that I got again (for HC only) is a passing one though I'm not sure if I'm going to live for example in California if that score would be consider as passing.
If I put back the cat, I could probably pass in the US.
