Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jul 2011
    Good day mga sir,
    Paano ba mabubuksan o maisasara yung mga bintana na matigas/mahirap galawin? Ano yung oil na pinapatak? May 2 bintana dito sa bahay na hindi maisara at mahirap buksan.
    Salamat.
    Akala ko bintana sa auto.
    WD40?
    Sep 2009
    kung swing type, kahit anong langis oks diyan. lagyan mo yung mga hinges na kinalawang tapos dahan dahan mong yugyugin.
    alalay sa paguga pag kinain ng kalawang yung hinges, puwede maputol yan.
    good luck!
    Quote Originally Posted by LiempoBoi View Post
    Good day mga sir,
    Salamat.
    Usually the reason why the windows will not open is busted rollers or similar. It is really a case to case repair thing. You'll need to remove the window from the frame and check why it is hard to open/slide and try to find a fix for it. Just oiling it may not even to anything for it.
    As for the oil, what we usually use on gate and window hinges is yung used motor oil. Tumatagal siya compared to multi purpose oil. And its free. Mas maganda kung fully synthetic pa makuha mo hehe
    Sep 2009
    same, pero ako yung gear oil ng 2stroke scoot ko nagtatabi talaga ako for hinges and rusted thingys.
    just squirt some on the rusted area and let the oil to seep in and tadaaaaah!
    Jul 2011
    Sir babaran mo muna ng oil at wag pilitin sa isang direction, pag meron resistance yugyugin mo lang sabay lagay ng oil para ung kalawang e sumama sa oil palayo sa hinges
    Jul 2011
    Salamat sa reply mga sir at ma'am. Siguro may gamit yung sobrang oil mula sa 5k PMS ko. May kalawang ako na nakikita. Ngayon, 10 bintana na ang mahirap buksan or ayaw mabuksan. Pwede ba masira yung hinge sa mga ganitong scenario? Mahal ba palitan yung mg ganyan? Ito pala current condition ng mga bintana na sinasabi ko:
    Jun 2011
    same here with C4U wd40 lang katapat nyan....
    Yung wd40 mabilis matuyo. Pwede masira yung hinge depending on how bad yung rust. Suggestion ko is ibabad mo muna sa oil for a couple of days. Then try to open the window. Kung ayaw parin, add oil again.
Stuck window
