Originally Posted by
yebo
so maybe we better take this incident as a lesson for all of us! as a gift to our families this xmas, let's all buy smoke/fire deterctors and fire extinguishers. abc fire extinguishers cost only p1500-p3000 each at ace.
ako meron na, isang smoke detector sa kitchen, isa sa 2nd floor corridor, and all the rooms (just above the door para pagpasok pa lang ng smoke na-detect na). may 2 fire extinguishers din sa kitchen, and believe it or not, a 3/4 inch 20 meter long fiberglass fire hose at the second floor hidden inside the double walling of the family room. this fire hose is directly connected to a 2 cubic meter tank with a booster pump which is separately wired from the rest of the house, and also connected to the mwss line via a check valve (para may pressure pa din kahit walang electric power and also hindi bumabalik yung pressure sa mwss pag umaandar yung booster pump). it's easy to do with off the shelf components at your suking hardware. pm me with your email address if you want a diagram. it does not violate the mwss prohibition on booster pumps since it is not directly connected to suction from the mwss supply. even if you just use a 1/2 inch garden hose it's better than nothing, as long as you locate it in the living areas where you will need it most during a fire.
i plan to buy next emergency escape smoke hoods, one for each member of the family to be kept in the rooms. it's like a disposable gas mask that you slip over your head with a high temperature plastic visor and a filter, brand name is EVAC-U-8. problem lang is kung meron available sa pinas. reading that news about kc de venecia reminded me that most fire victims die of suffocation, something i did not prepared for. paranoid ako ano?
