Page 44 of 53 FirstFirst ... 34404142434445464748 ... LastLast
Results 861 to 880 of 1047
    future water of metro manila
    Old news pero ito na alternative and si kaliwa dam
    But the governent must stop giving permits to build condo. If the developer wants to build eh make them bulid their own water reservior for each unit. Make it expensive to build condos in the philippines. Stop na. Punong-puno na.
    MWSS wants Razon, Violago to drop Wawa dam case
    Louise Maureen Simeon (The Philippine Star
    ) - December 27, 2018 - 12:00am
    MANILA, Philippines — The Metropolitan Waterworks and Sewerage System (MWSS) is calling on the group of tycoon Enrique Razon Jr. and Oscar Violago to withdraw a legal case to ensure that a plan to construct a new dam in Montalban will proceed as planned.
    MWSS administrator Reynaldo Velasco said the plan to proceed with the new Montalban dam or much improved Wawa dam as a medium-term water source proposed by the two businessmen would hinge on their withdrawal of the case they filed against the agency.
    “The Wawa dam has been a project even before, but they are fighting over water rights. Violago used to own the franchise and filed a case before the Court of Appeals that’s why we can’t proceed,” said MWSS administrator Reynaldo Velasco.
    “I told him (Razon) that if they don’t release the 80 million liters per day (MLD) of water that Manila Water needs and they don’t withdraw the case, the project is a no go,” Velasco said.
    Razon is the chairman of the International Container Terminal Services Inc., while Oscar Violago heads the San Lorenzo Ruiz Water Development Corp.
    It was in 2010 when Violago accused Ayala-led Manila Water Co. Inc., the National Water Resources Board and the MWSS of blocking his company’s bid to develop the Wawa dam project.
    Violago claimed that while they had the water rights after their application in 1993, Manila Water managed to get a permit allowing them to make advanced collections from water consumers in 2003.
    Earlier reports even claimed that while Violago has been proposing for the development of the project more than 20 years ago, MWSS actually wanted to give the rights to develop Wawa to Manila Water.
    In 2008, SLRB already submitted a full feasibility study for the 80 MLD, which the MWSS now wants to be released in favor of Manila Water.
    Since MWSS owns the facility and the land rights, it wants the Razon-Violago tandem and franchisee to release 80 MLD to be utilized by Ayala-led Manila Water.
    “Wawa is to be finished in the next three to five years. I need the 80 MLD to be released because Manila Water can do it in one year. We will not allow it if they don’t withdraw, it should be a give and take,” Velasco said.
    The Wawa dam feasibility study is expected to be finished by the first quarter of 2019.
    A few months ago, MWSS shelved Manila Water’s proposed Laguna Lake project because it was deemed “expensive.”
    With the new proposal for the Wawa dam, which has a capacity of 500 MLD, Manila Water has to buy the raw water.
    Manila Water is already breaching the supply allocated for them amid increasing demand of about 1,640 MLD. It is even utilizing supply from the La Mesa dam which is supposed to be for reserves.
    MWSS continues to undertake new projects that can produce three million liters of water in the next five years including the 600 MLD Kaliwa dam, the 500 MLD Montalban dam and the 1,950 MLD “ABC” projects as alternative sources of water.
    With the ABC projects, MWSS hopes to take advantage of the untapped and water wastage from Angat, revive the Bayabas dam project, and push for the Candaba multi-purpose impounding dam project.
    The projects have a potential of producing 1.95 MLD, which will largely complement the existing capacity of the Angat dam, the main source of Metro Manila’s water supply.
    https://www.philstar.com/business/20...-wawa-dam-case
    #862
    MWSS wants Razon, Violago to drop Wawa dam case | Philstar.com
    yes. make it more profitable for them to build outside the metro.
    if outside metro manila doc eh may certain part lang din kung baga may limitation. Kasi if unlibuild yan eh another problem in the making.
    #864
    bottomline,
    dumadami ang taong nangangailangan ng matitirhan.
    so, aside from serious population control, what do you have in mind?
    population control in metro manila. cavite and some cities in visayas and mindanao.
    ibang klase yang cavite na yan ang dami pala tao jan.
    ito pala, by the month of mayo, ang angat eh above 180meters IF less than .20meters ang bawas everyday.
    Lagyan secretly ng contraceptive yun water natin.
    #867
    tawagin si thanos!
    Sep 2016
    #868
    May times na mahina na ang water pressure dito sa Pasig. Iniisip ko kung bibili na ba kami ng drum para lang may reserba kami kung maulit ulit yung mga water interruption gaya last year.
    #869
    bro update mo ako pag naka source ka ng drum ha [emoji16]
    di ko alam ano fair price nya eh, nakikita ko kasi online nasa 1.5k
    Kahit hindi mawalan ng tubig sa inyo, you can use it in case of emergency like fire. Ang problema lang na nakikita ko dyan eh pag walang lugar na pag lalagyan ng drum.
    We have two sa labas ng bahay. May takip naman kaya kahit matagal bago gamitin.
    #871
    Sigurado na yata may water shortage this year. Di umabot sa minimum level ang Angat Dam.
    Jan 2016
    #872
    Sa junkshop siguro mas mura.
    #873
    why settle for a drum?
    make it permanent.
    purchase a metal tank, and yet your nawasa flow into it ad libitum.
    install a float valve, that will close the nawasa when the tank gets full.
    #874
    make it permanent.
    We had ours replaced recently, cost P30k+ I didn't think it would cost that much.
    #875
    the quality and price of drums, vary greatly.
    design, size and material make, play very important factors.
    some years back, we bought a 5.5 foot tall stainless steel pressure tank for 10K.
    #876
    1000 gallons
    #877
    1000 gallons
    gosh...
    that's big.
    refill twice a week?
    #878
    gosh...
    that's big.
    We just filled it and will use when the water supply is cut
    #879
    baka walang warranty bro eh LOL
    i mean baka di pwede ibalik incase may butas.
    Sep 2016
    #880
    Sabihan kita sir pag may nauha na ko.
    make it permanent.
    Dito kasi sa temporary home namin doc di kaya ang tank. Kaya settle muna sa drum temporarily din.
    Plan ko din kumuha ng tank in the future pag okay na permanent home. Plano ko nga rin another separate tank or just a drum to store rain water para naman sa pangflush/pang dilig o sa ibang mga gawain na pwedeng tubig ulan lang, pwede na.
Impending Water Crisis??
