Results 1 to 10 of 48
December 17th, 2006 12:47 AM #1
Hi guys, advance Merry Christmas to all=p Hahaa
Need help here guys, any solution sa acne problem (pimples, whiteheads, blackheads, Open Pores, Scars) Ano solution dito? Any remedy's or mga bawal kainin or bawal gawin, Meron ba kayo marecommend na Dermatologist? Thanks
December 17th, 2006 01:05 AM #2
in my own experience, umiinom lang ako extra daming tubig. kasi sa ihi lumalabas ang dumi sa katawan, pag hindi ka uminom ng maraming tubig, saan lalabas yan? eh di pores ng skin mo. yun kasi ang gumana sa akin....
December 17th, 2006 03:16 AM #3
Just keep your face clean, at iwasang maging oily yung skin sa face. Pansin ko kasi, yung may mga acne, usually kintab din ng mukha.
Sabi nila yung pagpupuyat, nakaka-cause ng acne? Totoo ba ito?
December 17th, 2006 10:31 AM #4
December 17th, 2006 11:18 AM #5
Lots of factor affects kumbaket may acne ang isang tao. Pwede stress, environment, etc.
Basic rule. Keep face clean. Do the three steps. Cleanse-Tone-Moisturize.
If you have oily face don't overwash. Tendency is the skin dries out so the skin reacts by producing more oil...or sumthin'.
Try using Loreal Pure Zone "Pore target technology" line. Its active ingredient is salycilic acid best for acne/milia/blackheads. I use them and I especially love the toner and the facial scrub. It works almost immediately and its cheap compared to other skin care line.
Benzoyl naman works but it leaves blemishes.
For scars I use tretinoin. It is also perfect for acute dermatitis but I rarely use it kase it stings and it peels. So i use it for scars lang since there's a peeling effect so the scars fade in time. Just don't expose yourself to the sun when you use this. I use to source it out from my derma but she overprices. Luckily, Derm-A has them. You can find them at selected department stores. It's not more than 300 pesos for a 20g tube.
You should also go to a reputable dermatologist first to assess what could be the factor for your acne. I couldn't recommend one since I don't know where you live. Better ask around in your neighborhood who's the best in the area.
December 17th, 2006 11:22 AM #6
go see a dermatologist, self medication sa mga ganyan lalong napapasama...I think kung bakit nagkakaacne pag puyat is bec I read it somewhere na around 1-3am nagoopen ang pores sa face natin para mag breath, so pag puyat ko or sa agimmick ka pag nagopen na pumapsok ang dumi tapos mag clog na so acne na sa umaga...
December 17th, 2006 11:35 AM #7
mag accutane ka, todas pimples mo... pati bulsa mo todas, ginto presyo nito. I think one tablet is around 90 pesos. Pero you would need a prescription from a dermatologist to be able to buy this from mercury
December 17th, 2006 12:34 PM #8
Problem ko din dati yan he he
always keep your face clean lalo na bago matulog, use the mildest soap you can find,
acne is caused by bacteria feeding on the oil of your face kaya para mo silang ginugutom pag walang oil, antibiotic works pero dapat mag consult ka sa doctor, sa generika outlets may antiboitic na mura
eat lots of fruits, banana ang nag work sa akin, ipinalit ko sa isang meal ko sa isang araw ang fruits, tsaka enough sleep, solve na problem mo
June 23rd, 2007 05:42 PM #9
June 23rd, 2007 05:48 PM #10
Pag mahilig ka raw sa mani, nakaka-cause din daw ng pimples. Totoo ba ito?
high idle RPM at engine start
