Quote Originally Posted by bongliza View Post
mga sirs, we are planning to buy a submersible pump for our deep well. depth is about 25meters, water level is about 15-20 during summer, tank level from well is about 8meters (mas mababa po ung well sa bahay namin), distance from well to the tank is approx. 30meters. 6-10 pers in the house.
please i need your advise on:
1. pump size in HP
2. anong brand po maganda? max budget is P15K
3. what else do we need?
thanks po sa advise.
Trouble of using subme pumps is yung stillness nya down there. Which will results into malabong tubig. The good thing is flow rate is very high compare sa jet pumps. If you can fix it securely downside for a try or comparison then, its ok.
BTW, there are jet pumps sold out there na "high heads" for that invert elevation of water surface I think you need high heads jet pump. And also you need "circuit breaker" na para lang sa kanya.
