Results 41 to 47 of 47
September 1st, 2019 03:01 PM #41
Retriculation system is basically plumbing work. The network of perforated pipes must run under, along walls & between to ensure proper termicide dispersion during periodic application. The more inlets & the shorter the pipes between inlets, the better. Ask your architect or builder to lay the system in before you pour your basement or ground floor. Cost will be dependent on structure footprint & total pipe length required....It's not a significant amount relative to total construction cost, ray bai.
- Oct 2012
- 4,851
September 1st, 2019 03:29 PM #42
September 1st, 2019 05:53 PM #43
Simple lang yan. 1/2" na blue pipe ilatag grid type sa ilalim ng semento sahig while construction then yun dulo nakalabas kung saan man para doon na lang inject yun treatment. Perforated nga pala para kumalat yun gamot.
Ganyan ginawa nun nagpagawa ako ng bahay.
September 1st, 2019 06:06 PM #44
What I am doing now is buy Bayer Agenda and apply it myself before pouring slab on fill, I will buy the bait separately when the house is finished. In our current house, termite treatment was done after it was constructed so NoKaOi did the bait system.
September 2nd, 2019 12:09 PM #45
- Mar 2017
- 257
September 2nd, 2019 07:57 PM #46Biotech is an authorized Sentricon operator. They are not cheap, pero sulit. We've had a very good experience with them.
Home Page - Bio-Tech Pest Control
September 2nd, 2019 08:48 PM #47
Exterra termite baiting system Philippines review | Pest-Ex – Pest Ex Philippines
Please note that a baiting system's efficacy will rely on monitoring frequency. Check reviews of the authorized providers. Both Sentricon & Exterra are proven systems.
VinFast VF 3
