Results 1 to 20 of 151
Threaded View
    Nabanggit mo premature ejaculation. Sa pag-aaral its a combination of psychological and nutritional problem. Pati mga chupot problema yan. May barkada ako kinakantiyawan namin dahil nilalabasan agad sa sauna bath. Eh tinuli na yun mag4th year highschool na.
    Gusto nyo usapang christianity. Ito maganda explanation.
    God commanded the Jews to be marked in their flesh so as NO ONE would ever doubt they were part of Israel. When it started, the ones circumscised were not children, but adult males. Then after they were all circumscised, then the regulation for the 8 day old males. It was a guarantee they were part of the covenant.
    It does not relate to infant baptism at all. It does relate to adult baptism for remission of sins, and is referred to in parallel, as the spiritual circumcision of the HEART. The seal or guarantee that YOU are a part of the NEW Covenant.
    Hope that helps. BTW, infant baptism is not salvational baptism, no matter what people teach. Part of the reasoning in baptism is YOU consent to having your sins removed because YOU repent from sin. Babies cannot repent from anything and they have NO sins for which to repent. Neither can they confess Jesus as their saviour. This false teaching, I am sorry to call it that, is from the Holy Traditions of the Roman Catholic Church, which are held in equal esteem and inspiration as the Holy Bible, even when they contradict each other.
    Usapang hospital naman
    "Most doctors recommend that circumcision be done within a few days from the delivery of the baby. Some doctors recommend waiting two or three weeks. When the birth occurs in a hospital, circumcision is usually done within 48 hours."
    How is a circumcision performed?
    Hospital/Doctor’s Office: The procedure can take from 5 to 20 minutes and will usually be performed before leaving the hospital. Your baby will be placed in a padded restraint chair and usually be given anesthesia.
    Home/Jewish Facility performed by a Mohel: Often called a “bris” or “holistic circumcision”, this procedure takes about 15-30 seconds. The foreskin is separated from the glans, often using the Mogen clamp, and then a single cut with a scalpel is used to remove the foreskin.
    The parents hold the baby during the procedure. Afterwards, the mother is encouraged to nurse within the first minute following the procedure. This procedure is usually performed on or shortly after the 8th day from birth when clotting factors in the babies blood are at their highest levels.
    Circumcision: Benefits, Procedures and Risks
    So yung tuli tradtition dito sa pinas na "before highschool" eh its just like the nazareno tradition. (Superstition na suswertehen pag nahipo yung statwa.)
    Sa tuli tatangkad daw. Syempre tatangkad kasi nasa adolescent stage. Subukan nyo magpatuli ng senior citizen na. Tingnan ko kung tumangkad pa.
    so, what's your stand on this, po?
Help - Circumcision
