i got a curious, unsolicited response from the salesman at Ace Hardware. Sabi niya the Navigator brand of gensets have some sort of tie-up with Honda?
Kung bigtime ka you can buy from Powerasia, FG Wilson brand nila. Smallest is 11KVa. Around half mil petot. Kaso sold out na. Next smallest that is available is 13KVa.
Yung motor or yung dynamo? Pwde kc sa motor lang di ba?
Kasi naman ang Honda, 4 to 5 times ang mahal kesa sa Raon at Evangelista hehehe
Pero sa portable gensets, Honda ang sukatan kahit sa ibang bansa.
i find the claim dubious as well. Kahit na yung engine lang ang Honda, i'd expect it to be more expensive. Maybe the engine is China-made, copied, este, based on an old Honda engine
Ganyan din advise sakin. It's not as if gagamitin siya araw araw sa jobsite. Though it would be really cool ^_^
Between Kipor and Navigator, alin po ang mas maganda? i know both are China made, but Navigator is at least 15k cheaper for the same model(5kva diesel). Both have service centers naman daw dito.
^^^ Bro,- I suggest you purchase at least a 7KVA model,- para pasok ang isang 1HP na aircon sa iyo... Pag 5KVA kasi,- medyo hirap IMO,- pero mathematically,- kaya naman.... (dahil may kasama pang iba - refrigerator etc...
25.8K:shazam:
Have a 3.5kva navigator genset, so far happy with its performance.
mga ka tsikot..
we have on stocks large capacity gensets.. 938kva 1000kva 1250kva, 1500kva, 2500kva.. on stock yan sir..
pati pang power plants meron kami.. pati biogas powered...
mga ka tsikot..
Grabe laki ng capacity.
On a similar note, pwede ba gumamit ng portable generator power sa mga inverter ref and air-conditioning units? Sensitive ba eto?
I know tv and computers are a no no unless you have a true sine wave inverter generator. Unless you have a UPS backup
The gensets sold here have voltage regulators but i doubt if its clean sine wave generators since portable lang and less than 40t pesos.
Any inputs will be great since this month na simula ang brown outs of the aquino government. Like mother like son hehe
^^ kapag ang supply ng AC current ay fluctuating (like meralco) kailangan ng UPS para laging constant ang current supply nito pero kung ang appliances naman ay auto volt from 110v to 220v no need na
Ang mahal din ng large capacity UPS bro, hehe. Kaya balak namin tutal daytime lang naman ang brownout according to Sec. Petilla, mag-mall na lang or hotel. To be fair di naman kasalanan ng current admin yung shortfall sa power. It takes a long time to put up power plants. Si GMA ang hindi naghanda ng future capacity. Ok din lang ako sa ILP, yung mga komunistang nagpipicket lagi sa Mendiola na lang ang magtiis sa init at dilim kung gusto nila.
uls
post mo na available units mo.
a friend of mine is looking for one.
uls
salamat mga kapatid.
Got mine sa miguel motor electrical supply. 713 evangelista for commandant quiapo manila. 313 5899 381 82 44 5.5 kw gen set diesel. kala ko 6 kw. 35,000 last 7/28/14 2 years service warranty siya
Fired/Warmed up our genset last weekend...
Running A-OK.....
25.9K:branch:
DIESEL OR GASOLINE FED GENERATOR
1. Can you pls share your opinion here what would be the pros and cons for each, aside from cost difference and noise level. Noise level is not an issue for me, and cost is a matter of upfront CAPEX (in favor of gasoline) vs regular fuel OPEX (in favor of diesel).
2. Also, I can see some ads saying inverter type and non-inverter type generators - what does each mean?
3. I need to provide for all lights, 2 LED TVS, 1 ref, 1 desktop PC and 2 electric fans. Is 6kw or 6 kVA more than enough?
4. What is the difference between kW rating and kVA rating?
5. What is the significance of single phase vs triple phase? What is suitable for home use?
6. And what is the significance of power factor, is it relevant for home use?
7. Can you recommend a good shop or seller for generator for home use?
Thanks for those who can help me understand.![]()
Not to be rude, but you are asking a lot in one post. I suggest you google first, and ask here what you do not understand fro your own research.
I am willing to answer some of your questions based on my own googling but first, how much is your budget?
If I am correct, diesel gensets are more expensive than gasoline gensets. You can find diesel genset only from units with output of 3000watts up. Lower output gensets are gasoline fed.
Inverter- more expensive but also more efficient than common gensets.
6kva genset is more than enough for the specified appliances.
kw vs kva? Yan ang ndi ko alam. Hahaha
Sent from my GT-N5100 using Tapatalk 2
