Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Apr 2003
    if you were renovating your place like an apartment would you wallpaper or paint? malayo ba cost? if existing is wallpaper mahirap ba ipaint na lang?
    I was told they'd last 4-5 years so same lang halos lalabas yung lifespan nila.
    sensya na at puro house related mga posts ko
    i would choose paint
    sa paint kasi madali lang i DIY lalo na kung smooth out na ang pipintahan...
    roller mo lang ayus!
    saka mag roller ngayon yung double headed, parang antique/marble finish (depende sa kulay) 2K yata ito or may ginagawa ang mga pintor using a sponge parang multi fleck finish...
    IMHO, mas mahal ang wall paper pero mas maganda. Yung paint mas mura and mas madali i maintain and i repair kung medyo magkaroon ng defect.
    Sep 2004
    if your place is in a moist area, i suggest you use paint.
    In my opinion, i'd rather have it painted instead of wall paper, now a days, you can paint walls that somehow looks like wall paper and it's more durable.
    If you have wallpaper, make sure you take it off first before painting. the trick to wall paper removal is to wet the wall paper before pulling it off
    Feb 2005
    imho paint is better. you can achieve wall paper designs sa paint. Also, easier to maintain ang wallpaper. if you're location is dusty, it would be a problem, mahirap linisin yan. and if may moist pa, most probably magkaroon ng discoloration yan and expect it to peel earlier than expected.
    Feb 2005
    also, another tip. if your walls are not that flat, i mean medyo di maganda palitada, never use glossy paint, mag flat ka lang. kita kasi ang imperfections nun. :D
    paint would be the practical choice. ;)
    Aug 2005
    paint na lang , use BOYSEN multifleck or Boysen Decore (mas mahal), try to visit boysen website www.boysen.com.ph
    Mar 2005
    wallpaper for bedrooms. paint for other rooms
    tama paint na lang, kung mag wall paper ka naman siguraduhin mong magaling ung maglalagay. kasi ung sa tita ko ang panget nung wallpapaer, nag peel ung mga edges tapos may mga bubbles pa. ang panget talaga.
home renovations
