Results 1 to 4 of 4
    when i double click on Add or Remove Programs in Control Panel, i get this: Parser Message: Value creation failed " at line 472.
    i'm using winxp sp1.
    Signature
    Jun 2004
    try this (nahanap ko lang using google)
    1. Open Control Panel.
    2. Open the Display applet.
    3. Select the Themes tab.
    4. In the Theme drop-down box, select Windows XP.
    5. Press Apply and OK.
    salamat! na-access ko na add/remove programs. pero balik din ako sa boring winxp theme
    Signature
    Feb 2005
    This is one of the most common problems of SP1. Sa shellstyle.dll ang problem nito. Try mo yung suggestion ni Chris. If this does not work, try this:
    1. Go to your folder where your themes are located (usually nasa C:\Windows\Resources\Themes yung mga themes).
    2. Open the folder of the theme you are currently using.
    3. Locate then open the folder named 'Shell' on the previous directory. Inside you would find the file 'shellsyle.dll'.
    4. Rename this folder where this file resides to the name of the theme you are using. Example.: your current theme is named 'Alpha' the you should rename the 'Shell' folder to 'Alpha'.
    8. Re-apply the theme.
    0. Finally, go to Add/Remove programs.
    Hope this helps.
Can't access Add or Remove Programs
