Results 1 to 10 of 30
    Jun 2009
    Ask your dentist first. Or if you like to experiment, try to use Lactacyd.
    Quote Originally Posted by nickriingen View Post
    should the Lactacyd be taken from the bottle or from where it's supposed to be use...:naughty2:
    and since we are talking about experiments, then pwede siguro yun first pee in the morning...:rofl:
    Napanood ko sa tv, ginagawa nga yan dati. I think it's because urine contains acid ata?
    Bactidol or Betadine gargle in 1:10 ratio with H20.
    I gargle 10 ml of pure Bactidol when I have sore throat. Otherwise, I use Orahex which I buy from my Dentist. It's supposed to keep your gums nice and pink.
    ah yes i use pure as well for tonsilitis, pharyngitis, gingivitis and more. Difflam is also good medyo mahal lang.
    I normally use Listerine Freshburst, and then I recently tried Colgate Plax Coolmint(?). I notice that Listerine attracts ants, while Colgate Plax does not. Is it because Listerine has more 'acid' in it? Hmmmm.....
    Bactidol, occasionally when I have sore throat. Our dentist does not recommend using it often....
    Are you serious about Lactacyd?
    9000:snowfight1:
    Jun 2009
    The normal urine pH ranges from 5-9 SI/conventional units, it depends on a person's diet, fluid intake, and physical fitness. But most often it is slightly acidic to add special precaution to kill off organisms found at the urethra.
    It's clean ... so there's no harm in drinking it. Assuming it's coming from a healthy person.
    Quote Originally Posted by cktlcmd View Post
    huwag naman drink over na yun, gargle lang...sigurado tangal ang sugar sa mouth ng TS.... although I know some people believes that it can cure their diseases if they drink their pee...
Best Mouthwash
