Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Oct 2003
    Peeps, help naman. Kalilipat ko lang sa antipolo sa may sumulong side. hirap makasagap ng tv station maski na outdoor antenna. gamit ko yung fake na baron super antenna worth 100 petot. sa cainta kami before but this fake antenna works fine.
    anyone who could attest that this baron super antenna really works on high lands like antipolo. meron itong 3 model. meron pang city then pag high lands then anywhere daw. i know na dapat eh naka mag subscribe na lang kami sa cable pero im in tight budget kaya naisipan ko ito.
    pls share your experiences on this.
    Sep 2005
    mura lang yata cable dyan.. ask around..
    mahirap talga signal dyan lalo na pag rainy seasons. maganda lang reception dyan channel 39 yata (basta yung tv station ni RJ jacinto). andyan kasi sa antipolo yung transmitter tower nya. tapos balita ko, may mga radio stations dyan malapit sa sumulong ng NICA (National Intelligence Center ek ek, basta military radios) kaya malakas interference. I tried one of those baron antennaes pero para wa epek. not all channels will clear up so nagtyaga na lang ako dun sa indoor antenna na adjustable, yung parang merong dial na naa-adjust yung resistance ng antenna mo. works fine on most tv channels. minsan, kelangan mo hawakan yung antenna para ikaw mismo yung human antenna - beri epektib yan...wag mo lang gagawin pag may thunderstorm hehehe
    Sep 2004
    Quote Originally Posted by rsnald
    Very true. Lagi na lang akong pinagtatawanan ng misis ko pag hindi ko mabitawan kung antenna, kesa masira yung panonood niya ng Oprah.
    Feb 2005
    wala na kasi si ka ernie kaya di na epektib
    Dec 2002
    re-branding daw...Kuya Kim Antenna na! j/k
    Meron kami dati ginagamit sa office, mga japanese made and very classified yung info like yung mga tolerance, etc.
    And sa Raon ko lang binili yun, forgot ko na brand eh and cost about a thousand bucks....tapos pinarisan ko ng antenna rotator para presto, na-adjust ko pag malabo minsan ang signal.
    Also, when buying outdoor antenna, dont forget to buy also lightning arrester.
    Pa-cable ka na lang Bro. Walang kwenta yang Baron antenna na yan. Sa commercial lang "maganda" yan. Meron kami niyan, pero wala rin.
    Sep 2005
    Quote Originally Posted by Bogeyman
    Di ba si Mr. Bean ganyan din
    Try mo lagyan ng fork ung dulo ng antenna.... most of the time it works eh..
    Sep 2005
    Better see what your neighbors are using and ask about their reception quality. Pero kung pangit din ...
    Basically, the bigger the antenna, the better it is - if it's properly designed. And bigger means more expensive because of the cost of materials. Along with your location, the intended frequency coverage (VHF and/or UHF) also dictates what type of antenna that's good for your location.
    A log periodic dipole array or it's variant is a good antenna for TV's. It has wide-frequency coverage, medium gain and looks similar to this:
    No sure antenna solution to your problem, because it all depends on your location. You may try a fork and see if it works.
    May booster din na binebenta sa RAON for antennas. Ewan ko lang kung gumagana.
    Feb 2003
    So if this is intended for VHF and UHF signals meaning....nde sya makagain ng signal for a weak FM receptions?...My area was having a bad Manila FM stations since some local FM stations sprouted..am thinking of having one of this Baron antenna do u think guys it will help solve my FM stations problem?
    There are indeed areas where reception is 'bad' no matter what antenna you're using. Please ask around so that you have an idea what situation you are in, before investing in another antenna (or deciding if you're going to subscribe to a Cable TV provider - I read that you're tight on budget...)
    Sep 2005
    Can anybody post a picture of the Baron antenna?
    Apr 2005
    may website yata yan. i-google mo na lang.
    Jun 2010
    eto baka makatulong sa inyo
    eto gamit ko ok para akong naka kabli
    Jun 2008
    Quote Originally Posted by danfred View Post
    Sure ka jan brader! para kang naka kabli? Curious...kuha ba jan ang HBO, Cinema One, Star Movies atbp?
    Jun 2010
    depende sa lugar tol
    san location mo
    Feb 2005
    *danfred, sa valenzuela, ok kaya reception nyang antenna mo? thanks!
    Jul 2006
    Tingin kayo dito sir Antennas
    Regular broadcasts lang dapat ang masagap ng aerial antenna....
    10.2K:chicken:
Baron super antenna
