Results 11 to 13 of 13
August 2nd, 2012 10:45 AM #11
i like asphalt roads. quieter, easier on the suspension if paved properly. and for me parang mas grippier... on dry that is. pag wet i find it slippery talaga.
Even on running its easier on the knees and other joints. I can run longer on asphalt too. On roadbike or racer, its smoother, and less body fatigue kaya I can bike longer. And pag sumemplang ako mas mababaw sugat ko on asphalt roads.
August 2nd, 2012 05:36 PM #12
concrete roads are better if the slabs are poured as 1 long continuous slab then later cut by a concrete cutter to allow for thermal expansion. example is congressional avenue when they first laid the concrete, the slabs were actually more than 100 meters length each, then cut every 5 or so meters to allow for thermal expansion. but if the slabs are poured as short slabs (like they did and continue to do on edsa) the joints tend to act as pivot points, late on causing the slabs to become slanted. para tuloy nakasakay sa kabayo, especially the south bound lane in front of SM north.
the reason our asphalt roads do not last long is because the quality of the asphalt is not good. matabang. as usual, 10% dito, 10% dun, minsan 20% pa. bakit sa ibang bansa ganda naman ng asphalt roads nila. e kasi walang kurakot!
August 2nd, 2012 09:04 PM #13
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
