Results 1 to 15 of 15
  1. Heretic Guest
    I went to Ever Gotesco last night to shop for groceries. Upon arriving home, I was greeted by my nephews for a surprise visit. I had to use my shoulder in bumping the door open since I was carrying two grocery bags. However, there were to kids who were playing inside that I didn't notice earlier. Too late; they bumped on our old, eight-foot solid narra door and it hit me in the mouth so hard that I was KTFO. There was some minor nose-bleeding that I have encountered when I woke up and of course my jaw was hurting like hell. But the worst news was that I found out that I lost my two front teeth!
    The nearest dental clinic that I've went to said that they only do tooth replacements by hooking the false teeth up or by bridges. The first option is not possible since my teeth have very small spaces between them. The second option requires drilling of the teeth beside the lost ones in order to anchor the fixtures.
    I'm interested with permanent tooth replacement - the ones where they'll screw the teeth to your gums via a titanium implant or stuff like that. Do you know of any clinics/hospitals who do this? Costs?
    Thanks!
    Dec 2003
    wait mo si Cutedoc
    Sep 2004
    Paging cutedoc, our resident expert in all things oral...:D
    yah si cutedoc nga nasa isip ko nung nakita ko ang title...
    Yup, kailangan mo ng PDR... Painless Dental Repair para ganito uli ang grin mo
    Are the tooth that came off still in one piece or is it broken? How was the tooth stored after it fell off? If it was stored in milk and the gum area still fresh the dentist may be able to put it back and it will back to normal after some healing time. Otherwise check these places dental implants , dental implants 2, or contact The Philippine Academy of Implant Dentistry.
    May 2005
    cutedoc..... to the rescue
    kayang kaya ni cutedoc yan.
    Signature
    May 2005
    naku wala pa ba si cutedoc?
    naalala ko tuloy ung sis ko, na-chip off ung isang front tooth nya. nakatayo lng sya sa isang street sa katipunan tapos may 2 lalake na nagtatawanan at nagtutulakan. napalakas yung tulak nung isa so napasubsob yung kasama nya sa likod ng sis ko. as in nadaganan siya. so tumama ung face ng sis ko sa semento. naputol ung ngipin nya at namaga pa ung lip nya non at nagkagalos siya.. kase naman ang tatanda na nagtutulakan pa sa daan!! :mad:
    naka jacket ngaun ung sis ko. di na nya nakuha ang pangalan nung 2 guys dahil na-shock din siguro sya non. pinakain lang daw sya ng sundae sa mcdo, bilang sorry.
    Yung dentist ko, Dr. Edgardo Micu, specializes in dental implants.
    May clinic sya dito sa Robinson's Galleria... Hollywood Smiles (tel # 632-7449).
    Oct 2005
    sir harris aka cutedoc IS the man for you....wait naten sya.
    Quote Originally Posted by Heretic
    Thanks!
    if you lost your 2 front teeth, bridging it would be the fastest and more pleasing appearance compared to a removable denture
    fixed porcelain bridge has 3 categories:
    1. porcelain fused to metal - semi precious metal lines the porcelain, the downside of it, there would be a gray hue on the margin of your gums and restored teeth due to the metal w/c is bio incompatible with the gum tissue, however you could opt to use gold lining the porcelain though it would be more expensive.
    2. all porcelain crown - no metal lining the porcelain, best aesthetical appearance, no gray hues, downside of this, it cost a lot higher but its worth the price.
    3. porcelain hybrid (adoro, soldex, integrated abutment crown) - the porcelain is combined with a resin material and some other material which makes the crown less abrasive, if your opposing teeth is a natural teeth and you bite and or chew a lot, you have a mild teeth grinding, this is more recommended, however if a bruxism or night grinding is severe or advance case, then a mouth guard may be necessary to be worn at night to protect the porcelain crown(including all porcelain and porcelain fused to metal)
    if you dont want to harm the adjacent teeth by grinding it and reducing its size to act as the anchor for the missing teeth then a dental implant is more recommended, detal implants has 2 types:
    1. mini dental implants - w/c has a limited function and limited extent of usage
    2. standard implant - w/c is the gold standard as dental implant is spoken off, the difference with mini is the size of implant used, standard implants are the material i strongly recommend though its would priced a bit higher, but the long term result is guaranteed, you can check out www.bicon.com its one of the material i use, and if you are planning to have a dental implant placed, see a qualified dentist or oral implantologist, not all dentist practises or use standard implants=)
    i cant send you a private message to you heretic, so im gonna post my reply here:
    How much is the cost for two front standard dental implants?
    Any estimates for my recovery period?
    around 70k for each dental implant=) so for the 2 front teeth that'll be 140k
    downtime is about 5 days, however you could go back to work the next day, stiches will be removed within 5-7 days for proper healing, within those period you will have to wear a temporary denture, it could be fixed or removable, untill the implant osteointegrate(the implant binds with the bone) usually this will be like 3months more or less depending on the bone structure and the speed of healing and the osteointegration.
    after the waiting period and after the implant has totally integrade with the bone, then a crown could be constructed and attached to the implant.
    1. would it be painful? no, during the operation anesthesia is employed, so no pain on the treatment duration.
    2. would the implant osteointegrade? yes, but we should allow a healing time of at least 3 months or more as the case may be.
    3. would your body reject the implant? no, the material is made up of titanium, and coated with hydroxy apatite crystals (same as the human bone)
    4. what are the no-nos? no smoking, before and during and after, if necessary no more smoking especially during the healing phase for this would greatly affect the healing of the implant, no diabetes or heart disease, if there be any it should be controlled.
    5. would the procedure be long? no, it would only take 30 minutes to an hour, depending on the case, for your 2 front teeth, 30 mins will do.
    Feb 2004
    cutedoc, yung friend ko problem nya is yung isang front teeth nya patay na ata ang mga veins,so yung color ng teeth naging dark yellow. he wants na i jacket yun na porcelain, you think ok yun? thanks
    Jun 2006
    help!
    I chipped my first molar (lower jaw) just now.
    can the fillings be done in one visit to the dentist?
    I'll be flying to another country for a few weeks (a possibility of getting extended for 3 months) on monday so I may not be available for a second visit to the same dentist.
    my tooth exactly looks like this with the dentin slightly exposed.
    I don't feel any pain though.
Any dentists here in Tsikot? Permanent tooth replacement?
