Results 1 to 15 of 15
    Mar 2003
    will our local phones work in japan? triband p910? anyone?
    dapat 3G ang phone. AFAIK, your local provider will provide you a handset compatible with japan's frequency should you activate your roaming there.
    gsm fones are not compatible with japan's.
    Feb 2005
    Japan uses CDMA tech.. just like the 6630 which supports dual technology like GSM and WCDMA..
    WBR,
    I think japan is using CDMA.
    W-CDMA to be exact.
    Sep 2004
    Japan has a different technology. They are using Personal Digital Carrier or PDC. Right now, if you have a nokia 6630 or 6650 you can use those phone with your local sim and you can get a coverage. Just make sure int'l roaming feature is activated. If you dont have those phone, Globe rents them out for P75/day.
    Feb 2004
    there are some areas that use GSM, but for most areas, CDMA nga.
    andy
    Quote Originally Posted by mazdamazda
    W-CDMA to be exact.
    that is correct. I was just there a few weeks ago. They are using the 3rd Generation W-CDMA by carriers like NTT-Docomo. If you have the phones that av8or has mentioned or some other phone manufacturers that support a hybrid GSM/WCDMA network then you're good to go.
    You could also rent mobile phones at the Airport if you wish. Don't rent at your hotel because they charge more. The Airport rentals are the cheapest one's I've seen so far.
    Aug 2004
    promdi,
    tama si ssaloon. your triband phone will not work in japan. you'll need to use a 3g handset. they're available for rent inside the airport in japan. just slip in your simcard and it should work. just make sure your international roaming feature is activated before you leave.
    if you're a smart post-paid subscriber, you can roam on ntt-docomo or vodafone/j-phone.
    hope this info helps.
    manolet
    Mar 2005
    av8or5 is right!
    Mar 2003
    thanks sa mga replies, I own 6670 from singapore and 6680 from globe. will these phones work?
    av8or5, will it be charged to my bill? or do I have to make a deposit? the closest globe center here is olongapo branch, will try to there tomorrow.
    Feb 2005
    I think you can use only 6680 phone which support WCDMA signal in Japan, just have your sim on roaming to japan with GLobe business centers...
    6670 phone use GSM network on Triband only incl USA..
    WBR,
    Feb 2005
    Quote Originally Posted by av8or5
    Ito lang ang tamang sagot. Japan is neither GSM nor WCDMA.
    u need a quad band phone sa japan, yung 4g. a 6630 will do na. 6680 mahal n new release pa lang.
international roaming in japan. what band? 900 or 1800?
