Originally Posted by
busdriver
Same here ralliart. My S124 (M102 engine) overheated yesterday.
I guess its really the weather.
On the other hand, the engine should not overheat when everything is working normal.
my 1st suspect is the cylinder head gasket (just have them replaced)
if no water leaks from the engine, then the repair should be ok - no water leaks naman and the oil is normal, di sya naging parang milk shake. To be on the safe side, I have it re-torqued, imikot pa sya ng half turn, i'll still have to take it our tomorrow, to test.
noticed that the water is coming out of the reservoir on idle (after overheating)
this is normal because in a Benz the reservoir is an integral part of the cooling system. Water (ie steam if overheated) circulates in the reservoir as well, unlike Jap design reservoir. - may mga cracks na din yung reservoir ko, pero its a good thing na din, dun lumalabas yung pressure instead sa radiator..
is it advisable to remove the stock propeller and convert to an auxfan type coolling (ala front wheel drive)
what I did with my S124, I just fully engaged the main fan clutch in such a way that the fan always rotate with the engine. Sayang naman yung fan kung tatanggalin. - ganyan na din ginawa ko sa fan, naka epoxy na sya so kasabay a sya ng engine.
How's your radiator cap? Any noticeable leaks? Mine is bad, water is coming out of it. That's my suspect since the cooling system is not a sealed system anymore. That little leak from the top slows the circulation of water to/from the engine.- if the temp reached 100+, may steam na lumalabas.. pero wala naman dun sa cap area..
I'll keep you posted on my fix. pls update us too. Thanks. Goodluck.
