Originally Posted by
ronw123w124
If its for a Benz, I wouldn't use any other coolant except the OEM MB coolant or at least the Febi brand coolant, both are available at Delodur (German Motors)
If you have relatives in the US then you could do what I do, buy the only approved aftermarket coolant for MB, Zerex GO51, its available at most auto parts store in the US then have them ship it here, malaki ang kamurahan sa OEM coolant and it does the job well.
Benz yan at hindi Toyota, kaya wag magpapaniwala sa mga recommendation about Prestone or Toyota coolant, Di ko alam kung may adverse effect ba yung Toyota coolant pero yung Prestone masyadong matapang lalo na for models with aluminum cylinder heads, eventually kakainin nya yung aluminum and it will require a replacement of cylinder head which is very costly.
Benz yan at hindi Toyota, kaya wag magpapaniwala sa mga recommendation about Prestone or Toyota coolant, Di ko alam kung may adverse effect ba yung Toyota coolant pero yung Prestone masyadong matapang lalo na for models with aluminum cylinder heads, eventually kakainin nya yung aluminum and it will require a replacement of cylinder head which is very costly. And lastly, ALWAYS use DISTILLED WATER mixed with coolant
