Results 1 to 8 of 8
    Hi... I recently found that the rear passenger carpet was wet. I check the the side near the door and it's dry. I removed the front carpet and the rubber insulator and found water... I got the water out and let it sit outside the rain. When I checked, I found water again so its not coming from the A/C. I guess it would come from the vents or the front door weatherstip or the windshield... Anybody have similar experience with the W124? any help is greatly appreciated.
    dapat makita mo source of leak, could be from ceiling or b-pillar.. looks like you have to be inside the car during a downpour para makita san galing tubig. the tubes sa may ceiling could just be misaligned and can easily be taken down to be sorted out by experienced mechanic..hth..
    Feb 2005
    I would like to share this info to you (and others). Hope this help you find the source of that leak.
    Feb 2005
    (cont.)
    Jul 2006
    Hindi ko makita ang links ni Bob eh .... * TS .. may sunroof option ka ba?
    Feb 2005
    Partner, same as what I have posted sa board natin. In the same sequence (9 links). I do not know how to attach a file here.
Help...S124 passenger side leak
