gurus, quick question.. saan sensor nakakabit yung Fuel Economy meter sa instrument panel.. since umandar yung kotse, lagi syang nasa red, di sya gumagalaw. May this be causing the excess fuel consumption ng car?
Thanks!
Mark
Thanks!
Mark
From what I know, the fuel economy gauge sensor might actually be a oil pressure sensor. Unfortunately I am no MB expert.
I do remember experiencing the same on my 107 before. Found one of the "vacuum line" disconected at the engine bay. Sorry but I was not able to picture the part that was connected.... but it should something near the HVAC area.
Good luck!
Good luck!
The fuel economy gauge is a simple vacuum line routed to the intake manifold. It is a very rough estimate of your fuel economy. Maybe somebody routed it to a vacuum port that is always sucking air, or just plugged it off. I forgot if the system defaults to red when it's off or in the clear.
Regardless, I would find the vacuum hose and route it to the intake, near the brake booster. That's how it is in a 2.6, maybe the 2.3 is similar.
In principle, when you step on the gas, the intake manifold vacuum increases. So the economy gauge senses this and indicates the level of vacuum in the intake. The more vacuum, the more you are consuming fuel (since you're stepping more on the pedal). It's a glorified vacuum gauge. That's how it works.
What Pat said is correct .........
OR
Your air / fuel mixtures adjustments are way off spec...
Tama lang yan, 1,200RPM for 28 seconds pag start, bababa yan until 550RPM. Depende sa temperature ng makina yung RPM pag cold start. Cold start valve delivers more fuel sa cold start to warm it up faster. Then pagkatapos, patay na yung cold start valve once engine is okay na.
In earlier models WUR (warm up regulator) ang ginagamit. Similar function.
guys, quick update. Found the vacuum hose and it is connected to the intake manifold to the gauge... i can now see the fuel economy sensor moving.
bad news is, its always on the red zone of the meter.. have to have the engine tuned 'coz as mbeige suggested, the car's air/fuel mixtures are way out of spec, that why I'm only getting 5 km/liter..
Thanks..
