I paid for less than 6k. I strongly advise anyone to buy a charger, although I can't recommend a particular brand except for CTEK. My reference is one of our expert members' recommendation.
The link can be found in CX-5 topic. I'll see if I can post it here later.
Hello. Came across a local supplier of Optima AGM Batteries. They are supposed to be better than EFB. Unfortunately, I will have to wait more than a year as I had just changed my start-stop battery (my 3rd, in 3 years!) last month. Optima isn't cheap though but hopefully lasts longer. The Red Top model sells for P 15,400 while the Yellow Top for P 17,600. Recommended for Mazda 6 is the Yellow Top. Pricing in the US on Optima's website is $232 and $271 respectively. The local supplier is Allen Specialty Products along Tomas Morato. I didn't ask if they install and ensure the car's settings are maintained. At least there is an option and not locked into one brand or the casa. Let me know if any have tried an AGM battery in the Philippines and how well adapted it is for tropical use. Thanks.
Go for Optima...its a Spiral Cell Technology AGM Batt....for iStop Skyactivs, check YellowTop D35 SKU: 8040-218.
Ask for the freshest stock. I've seen them here.....But due to price, inventory doesn't move much. Warranty is 36mos in the US for non-commercial light vehicles.
The length should fit the batt tray w/o the OE protective case. Here are the comparative dimensions:
Optima D35: W=171.45mm L=238.25mm H=195.33mm
Stock Q85 EFB: W=173㎜ L=222㎜ H=202
We have a Mazda 2/2016, question with regards to the battery, we just got a test report that the battery should be replaced. Would getting a CTEK CT5 prolong the current battery life?
Or should I just purchase a new one then use ctek on new battery?
Current battery reading is:
VOLTS - 12.22V
MEASURED - 124 CCA
RATING - 355 CCA
TIA
Scrap my question, wala pala kameng istop. LOL!!!
Answering an old post and hoping to contribute. This is the battery I charged using CTEK.
Unfortunately, I forgot to take a picture during charging. I got an error during charging after 3 hours. I removed the charger and after a few minutes, I connected it to charge again. After several minutes, I saw the LED switch to "charging" and finally to "care".
This is an old battery and I have something on my mind on where to use it.
Buy the CTEK MXS 5.0, it can charge AGM type batteries that are used by Start / Stop and also motorcycle batteries ... Do not buy the CT5 model ... you will not be able to use it to charge standard batteries ... the CT5 is just marketing gimmick ...
CT5 Start/Stop Tech Info lists regular, EFB & AGM batts.
CT5 START/STOP
reliable naman siguro ang Mazda service centers since may Yojin-3 (plan to service at Mazda Cavite)?
wala namang horror stories? (parts not replaced; stolen items; ginawang driving school; to name a few)
May I know where you got these and for how much? I am looking for a portable charger myself.
Unfortunately, walang Nocos dito sa pinas.
Sent from my SM-G950F using Tsikot Forums mobile app
