Results 1 to 2 of 2
    Aug 2004
    2012 Mazda MAZDA3 Skyactiv-G Road Test
    Hey, Man, We're Saving the Planet
    By Erin Riches, Senior Editor
    We're supposed to be pedaling our way to 40 mpg in the 2012 Mazda 3. But we've just turned onto Big Tujunga Canyon, a great road that feeds into the famed Angeles Crest Highway, and it's empty. We floor the throttle without remorse.
    Fun driving ruins fuel economy. That's the ugly truth car guys confront every day.
    As tougher fuel-efficiency standards loom, Mazda is dealing with it, too. The current-generation Mazda 3 can attack a corner like no other economy car, but it has always had a comparatively big thirst for fuel. The most efficient 2011 Mazda 3 was rated just at 25 city/33 highway mpg.
    For 2012, the automaker has added a third engine to the Mazda 3 family — a direct-injected, 2.0-liter inline four-cylinder called Skyactiv-G — and it brings a pair of all-new transmissions with it. Fuel mileage climbs as high as 28 city/40 highway. And when we glance at the average mpg meter after our run through the canyon, it's still not that scary.
    Half the Sky
    A Mazda official tells us that Skyactiv is a marketing guy's translation of Nobi nobi, which means something like the "sky's the limit" in Japanese. That might not be entirely true, but it's a good story and it gets to the heart of what the Skyactiv technologies are about: They're everything.
    Last month, we drove a prototype of the Mazda CX-5 crossover, which will be the first top-to-bottom Skyactiv vehicle, incorporating an all-new lightweight body and chassis along with the new drivetrains. The idea is to build lighter, more efficient cars that get better mpg, yet are still fun to drive — exactly what you'd hope the enabler of Zoom Zoom would be doing.
    The Mazda 3 is still a few years away from a full redesign, so the automaker has swapped in only the Skyactiv drivetrains for this 2012 refresh, which also incorporates minor changes to the suspension and unit-body that provide a slight increase in rigidity, along with subtle cosmetic changes.
    Rated for 155 horsepower at 6,000 rpm and 148 pound-feet of torque at 4,100 rpm, the new 2.0-liter engine is standard on the i Touring model, which is now available as a sedan or hatchback, and on the new i Grand Touring model.
    Mazda is still offering its older, port-injected, 148-hp 2.0-liter MZR engine as a less expensive alternative on base i and i Sport models, while the 167-hp 2.5-liter MZR engine remains on s models for those of you seeking more torque (it's rated for 166 lb-ft at 4,000 rpm). The 263-hp Mazdaspeed 3 carries over unchanged.
    Sweated Details
    High compression is the key to the Skyactiv-G engine's combination of usable performance and excellent fuel economy. Until now, we'd only sampled European-spec versions of this engine running at 14:1 compression. For the 2012 Mazda 3, the engineers have lowered the compression ratio to 12:1 to accommodate our 87 octane fuel and the 3's more conventional exhaust manifold, which isn't quite as adept as the CX-5's 4-2-1 exhaust manifold at evacuating hot exhaust gases (and thereby preventing detonation).
    "The 4-2-1 exhaust manifold is big," Kenichiro Saruwatari, chief engineer for the Mazda 3, told us, "so we cannot package it in the current Mazda 3 chassis — it would touch the dashboard."
    Even 12:1 compression would be inconceivable without direct injection cooling the intake charge. A modernized injection system on the Skyactiv-G engine squirts fuel into the combustion chambers at higher pressure than on the automaker's only other D.I. engine — the 2.3-liter turbo on the Mazdaspeed 3.
    You'll also note that the new engine is undersquare, with an 83.5mm cylinder-bore diameter and a 91.2mm stroke, compared to the oversquare 2.0-liter MZR engine (87.5mm bore diameter, 83.1mm stroke). Undersquare engines have more compact combustion chambers and suffer less heat loss — Subaru has taken a similar approach on the 2012 Impreza.
    Mazda also looked for every way possible to reduce friction on the Skyactiv-G engine. An electronically controlled oil pump is better matched to the engine's lubrication needs, while a new water pump and redesigned fins in the radiator provide more efficient and consistent cooling. The pistons, connecting rods and crankshaft are all forged steel, and the engine has a roller-rocker valvetrain. The engine's variable intake valve timing plays a role in keeping the cylinder contents cool and helps reduce pumping losses in low-load situations.
    A Manual for People Who Like Manuals
    When we get into our 2012 Mazda 3 i Touring Sedan, we're assured it really is running on 87 octane. Our car has the new six-speed manual, which is Mazda's first totally new manual gearbox since the 1980s.
    "Most of the effort went into making the driving experience better," Dave Coleman, Mazda's head of sports car engineering for North America, told us. "Anyone who buys a manual transmission in a Mazda is doing it because they like driving."
    To that end, Mazda shortened up the shift throws (now 45mm versus 50mm on the old six-speed) while reducing effort levels. Roller bearings take the place of bronze bushings on the shift rod. There's a nice, positive feel as you slot into each gate, and the clutch take-up is much friendlier than on our long-term Mazdaspeed 3.
    With 12:1 compression, the engine has less low-end grunt than we remember from the CX-5 prototypes, but once we reach 3,000 rpm, there's ample torque and it's smooth all the way to the 6,500-rpm redline. It turns out to be plenty of power for the run up Big Tujunga, and we rip off more than a few heel-and-toe downshifts.
    Acceleration is just as acceptable on the freeway, and 6th gear isn't so tall that you're constantly downshifting. Fuel mileage is slightly lower with the manual (27/39 on the sedan, 27/38 on the five-door), but not low enough to deter us.
    But the Automatic Is Good, Too
    If you want an automatic, though, you're not losing out on much performance.
    The new six-speed automatic is locked up 88 percent of the time compared with 64 percent on the old five-speed automatic, a change that not only improves responsiveness but also contributes to a 7 percent improvement in fuel economy. The torque converter is only active below 5 mph, so it can be smaller, while the multiplate lockup clutch is much bigger — as is the torsional damper.
    Another change is the adoption of a mechatronic module that combines the transmission's electronic and hydraulic controls in a single unit that Mazda calibrates to compensate for minor variations that occur on the production line. The result is a transmission that can rev-match a downshift and still give you a smooth upshift.
    That's exactly what we get during an afternoon commute in an automatic 2012 Mazda 3. Downshifts are quick with this transmission, so quick that it's hard to imagine anyone paying more for an automatic-equipped s model with the 2.5-liter engine. Indeed, you'd have a quicker Mazda 3, but it wouldn't shift nearly as well. The automatic has a manual mode (push the shifter forward to downshift, pull back to upshift) but no shift paddles.
    Mazda conservatively estimates that an automatic-equipped Mazda 3 with the Skyactiv-G engine will hit 60 mph in 9.6 seconds — significantly quicker than an automatic-equipped car with the 2.0-liter MZR engine (10.3 seconds). A manual-equipped Skyactiv-G car should be even quicker.
    It's a Complete Package
    Although the drivetrains are the main story on the 2012 Mazda 3, driving this car on back roads reminds us why it remains a favorite of ours in the compact car class.
    Even the i Touring trim, with workaday P205/55R16 Bridgestone Turanza EL400 tires, has exceptional grip and balance through corners. Power steering assist remains hydraulic (albeit with an electric motor driving the pump) and the steering feel is beyond what any other automaker has achieved in this price range. Even with only 155 hp, the Mazda 3 is a purer sport compact than some other cars with 50-100 hp more.
    The 2012 Mazda 3 is also an excellent value. Our manual-shift i Touring sedan has essentials, including a telescoping steering wheel, Bluetooth and an auxiliary input (a proprietary iPod cable remains a dealer accessory), and costs just $19,245 (Php835,000?)— right in line with a comparably equipped Chevrolet Cruze, Ford Focus, Honda Civic or Hyundai Elantra. For the hatchback, it runs $19,745, which is $1,000 less than the cheapest 2011 Mazda 3 five-door (which only came with the 2.5-liter). And if you want the automatic, it's $850 more.
    Although the 2.0-liter Skyactiv-G will be the volume engine on the 2012 Mazda 3, the automaker isn't expecting an overall increase in Mazda 3 sales, which usually hover around 100,000 units per year.
    This is too bad, because the fuel mileage is for real with the new drivetrains, and unlike most other approaches to maximizing mpg, they don't put a damper on the fun. Instead, it's quite the opposite. The Mazda 3 has never been better.
    Aug 2004
    2012 Mazda3 SkyActiv - 2012 Mazda3 First Drive Review on RoadandTrack.com
    2012 Mazda3 - First Drive
    Sedan and 5-Door blend Zoom Zoom with SkyActiv technology.
    By Dennis Simanaitis
    October 13, 2011
    I’ve just had opportunity to drive a pair of 2012 Mazda3 compacts, both with Mazda’s state-of-the-art SkyActiv technology. Accounting for some 40 percent of its U.S. business, the Mazda3 has big-time importance for this Japanese automaker. Plus, this car is North America’s first application of SkyActiv, technology that’s immensely important in Mazda’s future.
    Why is this? Because, with all their virtues, Mazdas haven’t been particularly renowned for exemplary fuel economy. Zoom-Zoom? Yes! Best-in-class mpg? Uh, let’s savor Zoom-Zoom rortiness some more.
    A multifaceted SkyActiv technology has the impressive goal of improving fuel economy by a huge 30 percent. The moniker “SkyActiv,” by the way, is an English rendering of a Japanese phrase akin to “The sky’s the limit.” This was the approach Mazda engineers took in everything from the basic engine to enhanced application of this engine’s twist to the tarmac.
    As is well recognized, a higher compression ratio leads to more efficient production of power. And, actually, of course, it’s during the expansion stroke that this power is outputted—so, in a very real sense, high expansion ratio is the goal.
    A Really High 12.0:1—On Regular Gasoline
    SkyActiv achieves this in two ways, one literal, the other virtual. Our Mazda3’s dohc 2.0-liter inline-4 gets a compression ratio (and hence “real” expansion ratio) of 12.0:1. Ordinarily, regular-grade gasoline would knock—aka ping or detonate—with this elevated compression ratio, yet Mazda marketers felt that a premium-fuel requirement wouldn’t fit North Americans’ perception of value. (Curiously, Europeans aren’t as parsimonious; their SkyActiv gets even a higher premium-only compression ratio of 14.0:1.)
    One thing aiding 12.0:1 acceptability is direct injection. The DI-squirted fuel lowers the temperature of the combustion chamber, thus reducing the likelihood of knock. Also, Mazda’s high-pressure DI injects its gasoline with a six-hole spray pattern through a two-phase process, one late in the intake stroke and the other during the compression stroke. (Multiple injection strategy comes directly from the diesel playbook.)
    Another trick for lessening the propensity of knock and enhancing efficiency is to select a small bore/large stroke for the desired displacement. A smaller chamber gives faster combustion; less surface area gives less heat loss. Plus, such engine designs are known for commendable low-end torque.
    Other SkyActiv engine nuances include a carefully crafted piston crown defining a “combustion pocket,” again to lessen knock and enhance thermal efficiency. Reduced tension of the piston rings cuts frictional losses. Oil and water pumps are optimized for reduced drag. The crankshaft is forged steel—stronger than conventional cast iron; it’s lighter and can revolve on smaller bearings.
    Miller Cycle on Cruise
    The virtual portion of elevated expansion ratio is embodied in the SkyActiv engine’s Miller Cycle. This clever timing of intake valves virtually tricks the engine into thinking its expansion stroke is longer than the compression stroke. (It’s akin to Atkinson Cycle operation of many hybrid powerplants.)
    Electronic variation of the intake camshaft pulley brings about this late closing of its valves. Pumping losses are reduced by 13 percent. In result, it’s similar to BMW’s Valvetronic—but rather more elegantly simple in execution.
    As Miller Cycle typically comes with a reduction of output (Mazda’s previous application in its Millennia sedan was supercharged), SkyActiv employs it only at light-load cruise.
    In total, SkyActiv wizardry accounts for an impressive 15-percent improvement in fuel economy. Yet the new engine also produces approximately 15-percent more torque at low- and mid-range rpm.
    SkyActiv Transmission Trickery
    The Mazda3’s 6-speed transmissions, automatic and manual, both profit from innovation as well. The SkyActiv-MT manual is smaller and lighter, with less internal friction. Its shift mechanism is optimized to mimic the Miata’s exemplary feel.
    The SkyActiv-Drive automatic is particularly noteworthy in emphasizing the advantages of conventional automatics (good creep, efficient lockup), continuously variable designs (smoothness, low-speed efficiency) and the latest dual-clutch units (overall efficiency, quick shifting). It does this by combining a multi-plate clutch and torque converter of reduced size, each calibrated to function in its most efficient regime. The torque converter, for instance, is solely used at speeds less than 5 mph. Clutch lockup comes sooner than in conventional designs, thus aiding efficiency. Engineers figure SkyActiv-Drive is worth another 7 percent in improved fuel economy.
    The Proof is on the Road
    A half-day’s First Drive cannot tell the whole story, but the SkyActiv powertrains made their point. Particularly evident was the engine’s excellent low-end torque, whether teamed with SkyActiv-Drive automatic or the SkyActiv-MT manual.
    Engineers made a point as well on how integrated the process becomes. Torquey long-stroke engines produce a different acoustic signature, and thus everything from exhaust system to bodywork noise, vibration and harshness are affected.
    As already noted, SkyActiv-equipped models are only part of the redesigned Mazda3 lineup. The manual-equipped SkyActiv Touring 4-door I drove was priced at $19,245 (including its $795 destination). My automatic-equipped Grand Touring 5-door probably probed the top of the SkyActiv lineup at a total of $24,495. Important numbers for each—as in EPA Mpg, City/Highway, respectively—are 28/40 for the SkyActiv-Drive automatic and 27/39 for the SkyActiv-MT manual.
Mazda 3 SkyActiv (series)
