ano feeedback dun sa mga zeon ng shocks ang mura ahh
Bro walang positive sa suspension ng Mazda pangit talaga. May usdm 07Mazdaspeed3 ako at pinalitan ko ng KW variant3 coilovers ung shocks kasi makalampag bumagsak ung stock. Sa KW ok talaga parang Benz pero pay the price ika nga. Engine support pinalitan ko rin para sure pero 1 lang para hindi malakas ang vibration matigas kasi.
I ordered from Street Unit.com because it is a direct replacement than remove the part and have it fabricated. I heard it can be fabricated locallly by Zafra or M7 and others in the business. The engine support is the solid rubber type Bravoexo kaya parang diesel ang vibration but sure ako hindi mapupunit.
ah, I only wonder if I would need the third bolt though, since our units here have three bolts, for the passenger mount. Only hardrace has a 1.6L version though... it's the same stock metal mount but filled with solid rubber, like the Mazdaspeed stock mount. Only thing is they are always either out of stock or can't find all three from one source.
I've asked Zee Car plus before about polyurethane filling my wasted mounts... they adviced against it due to the vibes... only for racing per their suggestion... :P
Poly is definitely too hard. And drilling holes in poly is hit or miss. Drill one too many and it's too loose.
That's the problem with fabricated rubber, too. Drill too many holes and the mount becomes too soft, which means that you'll get clunk as the engine moves under acceleration.
M7 fabricates rubber and poly mounts... as does Cruven.
zombie thread revival.
had to replace my front shocks at 22T km (2007 mz3 hatch) back in jan 2009. As of a few months ago at 32T km, all the shocks now need replacement (again). only added 10T km in the past 2 years because parking lot queen siya ngayon (nagsapalaran ako hehehe OFW).
funny thing. i am now driving a 2005 mz6 with a LOT of miles on it (125T km). it's on its original shocks. which are not pristine (and napalitan na ball joints in front), but still in better condition than the mz3 back in Manila!
I've always felt that the stock shocks of the 1.6 are way too soft. The car moves around too much at high speeds (though not as badly as the Corolla). A good solution would be to forgo buying new 1.6-spec shocks and to go for the shocks for the 2.3 liter variant overseas.
ako rin,my shocks need replacement.ano kya the best na shocks para sa mazda3 2010?madami na rin akong naririnig na noise sa ilalim.san shop kaya maganda mgpasilip ng ilalim ng auto?need help po,please respond.thanks in advance.
mga sir, pa advice naman po kung san maganda dalhin mazda 3 ko for replacing rear shock absorbers and lateral assemblies, nag pa estimate po kase ko sa zafra here in Sto tomas Batangas, P15,810 quote nila parts and labor. ok na po ba yun? or you can suggest other shops? kahit po dumayo ako ng banawe. thanks
Try mo sa Cruven, search mo na lang sa internet yung location. Parang wala na kasi yung nasa malapit sa SM Fairview na pinagpagawaan ko dati. Sa parts try mo mazford sa banawe, di ko sure kung gumagawa din sila yan yung recommended shops ng mga naka mazda.
