Guys, baka matulungan nyo ko i have my problem matagal na sa failia 97 model (A/T). Everytime na ginagamit ko sya galing sa pahinga (min. of 5 hrs. rest) or park namamatay yung makina ko. Considering na kapapaadjust lang ng minor to 0.9 mga ilang araw lang baba nanaman ng minor sa 0.5 to 0.6 kaya hanggang ngayon ang baba ng minor ko. Pansin ko lang after gamitin ng 5 - 10 mins long run okay na takbo ang minor tumaas ng konti up to 0.8, napacheck ko na at palinis yung servo motor ganun pa rin ang sakit ng oto eh.
Another problem is kapag naka open A/C ko ang tagal ng response ng brake kaya malimit di ko ginagamit A/C delikado kasi.
Ano pa kaya pede ko pacheck? electrical? Alternator? help naman po. . . .
If your car is fuel injected, have your engine check at shops equipped with diagnostic scan tool. Don't let mechanics without using scan tool tamper or check the sensors using the usual kapa kapa, trial and error method or worse tantia meter. Bigger problem will occur once they do this since they will tell you to replace this and that without proper diagnosis. Others will tell you that the trouble lies on the ECU!
If your car is fuel injected, have it check at shops equipped with proper diagnostic scan tool. Don't let anyone without this tool diagnose your car since they will resort to the usual kapa kapa,hula hula, trial and error method or worse, tantiameter style. More problem will occur since they will advise you to replace this and that without the proper diagnosis.
Or may mairecommend ka na merong ganitong tools/ equipment. Much better po malapit sa Laguna.
