Results 1 to 4 of 4
June 2nd, 2010 07:47 PM #1
GLXi
1.6L DOHC EFI, All power (Windows, Steering, Mirror)
With ABS, Fog lamps, Rear Defogger
Sony Headunit w/ CD Changer
With Airbag, driverside only?
Automatic transmission
To the Mazda 323 gurus,
where can i get a car manual? fuse box (under the driverside dash) wala po kasi info kung ilang amps ang dapat gamitin and kung sang part ito connected.
tried to check all fuses, all of them are ok but the park lites and fog lamps are not working.. ang fuse po ba nito e malaki (located at lower right portion ng fuse box?)?
how about the engine, what model po ba nito, B6? anything i need to check? fluid requirements like engine oil, trans oil, etc + tune up sched may specifics for this mazda?
ABS gauge light is always 'on.' ano po problema nito?
steering wheel (with airbag). sira na po yun leather cover. can i have it fixed at seatmate without removing the s-wheel? magdedeploy yun airbag pag tinanggal diba?
sino po magaling na mechanic, a/c shop and electrician, makati area?
posting for a friend...
thanks in advance!
azzkkr2600
June 2nd, 2010 07:54 PM #2
- Dec 2008
- 73
June 4th, 2010 03:12 AM #3I had an exact model:
check/replace the park light relay under the dashboard/steering wheel (happened to me)
ABS light: my special diagnosis procedure para madetect ang exact fault code. (happened also to me, and replaced the ABS relay. Also nagkabara ang ABS pump ko, pretty expensive, got a surplus unit from the MTP boards for 7k pang lantis)
Steering wheel leather? aftermarket lang malamang yan. pwede palagyan mo na lang ulit, wag lang yung central part na kung saan sumasabog yung airbag
June 4th, 2010 07:46 AM #4
* zantets: thank you for your inputs! will have it checked with an electrician probably this weekend. ang prob ko pa is yun car manual kasi walang indicator yun mga fuse sa fuse box/fuse box cover. so hinuhulaan ko na lang kun pra san mga yun. wala ako mahanap sa net e.
high idle RPM at engine start
