Results 1 to 1 of 1
June 2nd, 2010 07:44 PM #1
GLXi
1.6L DOHC EFI, All power (Windows, Steering, Mirror)
With ABS, Fog lamps, Rear Defogger
Sony Headunit w/ CD Changer
With Airbag, driverside only?
Automatic transmission
To the Mazda 323 gurus,
where can i get a car manual? fuse box (under the driverside dash) wala po kasi info kung ilang amps ang dapat gamitin and kung sang part ito connected.
tried to check all fuses, all of them are ok but the park lites and fog lamps are not working.. ang fuse po ba nito e malaki (located at lower right portion ng fuse box?)?
how about the engine, what model po ba nito, B6? anything i need to check? fluid requirements like engine oil, trans oil, etc + tune up sched may specifics for this mazda?
ABS gauge light is always 'on.' ano po problema nito?
steering wheel (with airbag). sira na po yun leather cover. can i have it fixed at seatmate without removing the s-wheel? magdedeploy yun airbag pag tinanggal diba?
sino po magaling na mechanic, a/c shop and electrician, makati area?
posting for a friend...
thanks in advance!
azzkkr2600
samin doc sinasabihan kami "mag nilay nilay" - be quiet. Bawal magsaya (common sense) and music or...
Traffic!
