it just wont perform the its intended function.
From Yokohama Tire company
Designed to rotate in only one direction, unidirectional tires enhance straight-line acceleration by reducing rolling resistance. The also provide shorter stopping distance. Unidirectional tires must be dedicated to a specific side of the vehicle.
its not the question of "will it disperse water?" but rather HOW much water is dispersed or effective will it perform when not mounted properly on its specific side.
I guess the bottomline is HOW BIG is the chance of hydroplaning when mouted incorrectly. It was designed for a reason.
Yes I can wear my shirt inside-out, but was it designed to wear that way? NO. but does it serve the purpose covering my naked body? YES. But is it the 'proper way' to wear them? NO. But why would you wear a shirt inside-out? Because I can and I dont know better. :2hearts:
nakikita ko din dito yan, A4 na baliktad ang tread pattern. May nakita pa nga akong 7-series na nasa may lip ng rim ang wheel weight blocks :evillaugh
if you dont know the purpose of unidirectional, you may not want to buy/use it because it negates the absolute purpose of such feature.
sabi ni silverbx986 yan, palibhasa naka Porshe kaya pinaniwalaan ko, nyashshahasa
