Results 41 to 50 of 205
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 29th, 2006 09:41 AM #42just coz they're in magazines and win in the car show doesn't mean they know how to repair cars. it means marunong sila mag porma ng auto. if you need repairs, bring it to a repair shop and try to know what you want to have done rin para di ka lang oo ng oo kapag inalok ka ng parts kahit hindi kailangan.
- Jul 2006
- 52
December 29th, 2006 09:48 AM #43Yup alam ko yun ang mali ko..pero nagawa na sya and nagastos na ako..=(
Sa susunod alam ko na ggawin ko..wat tym po kau bukas?gusto ko n din patingin..tutal nagastos na din ako kya gs2 ko maayos n sya ng buo...haayy...lesson learned
- Nov 2003
- 3,849
December 29th, 2006 01:18 PM #45
speedyfix thanks for your quotation made by your thrusted mechanic rey, and according to them almost 2days working for my ride.... sana mabawasan pa discount kung pwedi hehehe
at pwedi ko ba post yong estimate dito ni speedyfix vs honda casa... just for comparison lang po mga bosing...kung pwedi lang naman e
- Nov 2003
- 3,849
December 29th, 2006 05:14 PM #46no problem! i'll give you a discount nalang when you have the work done
December 29th, 2006 05:58 PM #47
ok thanks, and here is the estimate by speedyfix vs honda casa
Speedyfix quotation
1.timing belt, 1,700
2.belt tensioner, 900
3.water pump, 1,500
4.fuel filter, 900
5.Air filter, 450
6.crankshaft oil seal, 300
7.camshaft oil seal, 300
8.valve clearance adjustment, 500
9.flashing brake fluid, 280
10.flashing power stering fluid 280
11.radiator coolant, 560
12.automatic trans fluid, 1,120
13.oil 8100 X-CESS, 2,560
14,oil filter, 200
15, spark plug, 400
16, valve cover gasket, 700
17, spark plug oil seal, 1,000
18, valve cover washer, 1,250
19. brake pad bendex, 1,100
20. labor, 4,450
total PHP 20,450.00 less discount = PHP 19,500
Honda Casa Estimate PHP 17,391 except Water pump and Brake Pad
Any comment and suggestion........thanks
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 29th, 2006 09:17 PM #48Clarify ko lang. You mean Honda casa estimate does not include brake pads and water pump. Tama ba?
Also ask Migs if you can avail of his P1900 oil change promo using Motul. As I understand it includes 4 liters of oil, labor and oil filter. Should save you some money vs the 8100 X-cess oil plus filter.Last edited by userfriendly; December 29th, 2006 at 09:21 PM.
December 30th, 2006 08:52 AM #49
yes sir, not included brake pad and water pump, as per service advisor of honda casa just check first before the replacement, and after that if the pump with leak or tagas its time to replace din, yon ang problema kasi mapapamahal din ako doon, kasi 4,500 and cost ng pump what do you think sir, kasi nag babawas na water ko sa reserved tank wala naman ako makitang leak and ask ko din speedy fix regarding oil promo. thanks sa advise mga sir tsikoters
- Jun 2006
- 2,605
December 30th, 2006 09:13 AM #50Usual advise is to replace water pump with timing belt. Its to save money on labor, isang trabaho lang. Also for peace of mind, mahirap pagoverheat. For the brake pads, have them measure how much pad is left. They can measure it. If its around 25% remaining change it.
To save more money, you can buy the parts yourself. Don't think casa will let you do this.
With any shop be it Speedy or casa or someone else, tell them to inform you of the findings or what parts need to be repaired or replaced and let you decide before proceeding. This way you know whats done and how much it will cost.
probably not... yet, siguro. too many unknowns, yet. but if the manufacturer would offer it to...
MG 3 (3rd Gen)
