Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 205
    #41
    speedyfix is one of the recommended shops here in tsikot. ;)
    Nov 2003
    #42
    just coz they're in magazines and win in the car show doesn't mean they know how to repair cars. it means marunong sila mag porma ng auto. if you need repairs, bring it to a repair shop and try to know what you want to have done rin para di ka lang oo ng oo kapag inalok ka ng parts kahit hindi kailangan.
    Jul 2006
    #43
    Yup alam ko yun ang mali ko..pero nagawa na sya and nagastos na ako..=(
    Sa susunod alam ko na ggawin ko..wat tym po kau bukas?gusto ko n din patingin..tutal nagastos na din ako kya gs2 ko maayos n sya ng buo...haayy...lesson learned
    Nov 2003
    #44
    we're open 9am-6pm mon-sat
    Nov 2006
    #45
    speedyfix thanks for your quotation made by your thrusted mechanic rey, and according to them almost 2days working for my ride.... sana mabawasan pa discount kung pwedi hehehe
    at pwedi ko ba post yong estimate dito ni speedyfix vs honda casa... just for comparison lang po mga bosing...kung pwedi lang naman e
    Nov 2003
    #46
    no problem! i'll give you a discount nalang when you have the work done
    Nov 2006
    #47
    ok thanks, and here is the estimate by speedyfix vs honda casa
    Speedyfix quotation
    1.timing belt, 1,700
    2.belt tensioner, 900
    3.water pump, 1,500
    4.fuel filter, 900
    5.Air filter, 450
    6.crankshaft oil seal, 300
    7.camshaft oil seal, 300
    8.valve clearance adjustment, 500
    9.flashing brake fluid, 280
    10.flashing power stering fluid 280
    11.radiator coolant, 560
    12.automatic trans fluid, 1,120
    13.oil 8100 X-CESS, 2,560
    14,oil filter, 200
    15, spark plug, 400
    16, valve cover gasket, 700
    17, spark plug oil seal, 1,000
    18, valve cover washer, 1,250
    19. brake pad bendex, 1,100
    20. labor, 4,450
    total PHP 20,450.00 less discount = PHP 19,500
    Honda Casa Estimate PHP 17,391 except Water pump and Brake Pad
    Any comment and suggestion........thanks
    Jun 2006
    #48
    Clarify ko lang. You mean Honda casa estimate does not include brake pads and water pump. Tama ba?
    Also ask Migs if you can avail of his P1900 oil change promo using Motul. As I understand it includes 4 liters of oil, labor and oil filter. Should save you some money vs the 8100 X-cess oil plus filter.
    Nov 2006
    #49
    yes sir, not included brake pad and water pump, as per service advisor of honda casa just check first before the replacement, and after that if the pump with leak or tagas its time to replace din, yon ang problema kasi mapapamahal din ako doon, kasi 4,500 and cost ng pump what do you think sir, kasi nag babawas na water ko sa reserved tank wala naman ako makitang leak and ask ko din speedy fix regarding oil promo. thanks sa advise mga sir tsikoters
    Jun 2006
    #50
    Usual advise is to replace water pump with timing belt. Its to save money on labor, isang trabaho lang. Also for peace of mind, mahirap pagoverheat. For the brake pads, have them measure how much pad is left. They can measure it. If its around 25% remaining change it.
    To save more money, you can buy the parts yourself. Don't think casa will let you do this.
    With any shop be it Speedy or casa or someone else, tell them to inform you of the findings or what parts need to be repaired or replaced and let you decide before proceeding. This way you know whats done and how much it will cost.
    Nov 2006
    #51
    Thank you sir, i buy and replace na brake pad ko, just cost 700 for brake pad and 50 for brake fluid, and labor is free, now na test ko na rin nawala na ingay nya at 750 total cost, salamat sa advice at least medyo nakabawas na ako ng konti.
    for speedy fix, tanong olit bakit parang ang taas naman ng cost of material mo 700 for valve cover gasket 1pc, 4 spark plug oil seal 1,000. at at bakit meron pang 8pcs valve cover washer for 1,250 sensya tanong lang po gusto ko lang po makabawas ng gastos na di naman mag supper ang engine ng ride ko. thanks
    #52
    Quote Originally Posted by BRROOOMMMM View Post
    for speedy fix, tanong olit bakit parang ang taas naman ng cost of material mo [SIZE="4"]700 for valve cover gasket 1pc, 4 spark plug oil seal 1,000[/SIZE]. at at bakit meron pang 8pcs valve cover washer for 1,250 sensya tanong lang po gusto ko lang po makabawas ng gastos na di naman mag supper ang engine ng ride ko. thanks
    first thing, I don't know Speedyfix personally nor am I a customer nor have I been to his shop for repairs, I only knew Speedyfix thru the Boards but I've heard a lot of good things about his shop
    As for the price of the Valve cover gasket and Spark plug seals, IMO they're within the OEM parts price range.
    When I bought my Pizza Lancer's valve cover gasket and plug seals about 3 months ago, halos ganyan din ang presyo. Note, what I bought are OEM's not replacements so probably those quoted to you are also OEM parts for your vehicle.
    #53
    hello Sir speedyfix,
    Im a newbie here, i just recently bought a 2nd hand honda esi 95 a/t. and planning to have a general car check up for this car since i'm experiencing some issues. are you open tomorrow for check-up and estimate?
    thanks a lot for helping.
    Feb 2006
    #54
    Hi speedy, patingin ko uli yung A/T ng Accord ko. Medyo malakas ang shift shock e. Please to also see why medyo rough takbo ng engine.
    Couldn't get it back to you sooner cuz yun yung service ko habang inaayos A/C ng E34.
    Nov 2003
    #55
    myhondaesi, we reopen on jan 3
    flagg, ayt! seeya!
    BRROOOMMMM, to make the cost estimate clearer it might be wise to also list down what was quoted to you by honda. it is kinda one-sided to know the breakdown we gave while you just give the total of honda. when comparing prices, also note the lubricants they use. i.e. did they quote you fully synthetic oil or just mineral oil? what grade? what quality?
    while you are more than welcome to purchase your own parts like the valvecover, gaskets, pump and belts we will not be able to warranty the work since we are not sure of the quality of the items you gave.
    for the most part, all of the seals we quoted you are oem parts, the replacement parts we quoted are those we are comfortable working with and have had no problems with in the past. if you've been in the business a decent amount of time, you will also understand that not all replacement parts are the same. quality differs greatly depending on the brand you choose to use... so does price. while brand A and B may both be replacements, both could vary in price by a large margin. we tend to use the replacement parts that are more expensive since they will last longer and cause us fewer headaches in the long run.
    sooo.... you can really supply the parts and save money, but if you do so please make sure you know what you are buying or else you will simply end up have to replace the parts twice instead of in one worry free move.
    Jul 2006
    #56
    Boss speedy...remember me? i went to your shop last fri..I am with the civic that has trailing arm problem..mga ilang araw ho ba mggawa ung car? taga pampanga pa kasi ako eh..tpos coding pa ako sa jan 3..=(
    Nov 2003
    #57
    maybe 1 whole day for the trailing arm and the other bushing na sira... bring it when you're free pero if you arrive in the pm baka next day na makuha
    Jul 2006
    #58
    me pasok na ako sa work sa jan 2 sa makati...and wala naman ako parking d2 sa manila kasi sa pampanga lng tlga gamit ung car...cge sa jan 4 ko na lang dalhin dyn sa shop mo boss..mkikisuyo na lng ako sa gf ko na i garahe mna sa kanila..Tnx ulit!
    Nov 2003
    #59
    no problem
    Nov 2006
    #60
    Quote Originally Posted by speedyfix View Post
    flagg, ayt! seeya!
    Happy new year Sir Migs of Speedyfix, and thanks for your good advice dalhin ko na lang ride ko dyan by thursday din final na lang natin yong gagawin sa ride ko saka more price discount pls.......
directions to speedyfix
