Results 171 to 180 of 205
December 1st, 2009 10:10 AM #171
Hi Migs,
How about alternators...do you repair or replace alternators? I have a feeling something is wrong with my alternator already.
If so, how long does it take to do so? Saglit lang ba yun...maybe a few hours?
Thanks.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 2nd, 2009 08:17 AM #172depends on the car. normally we have it serviced by a friends alternator shop. we'll need the car there muna though so we can check what is wrong and suggest kung palit or kaya pa ayusin.
- Jul 2005
- 430
December 3rd, 2009 11:05 AM #173
- Nov 2003
- 3,848
December 4th, 2009 09:03 AM #175
bro, daan ako bukas sa shop niyo. around 10AM pag nagising ng maaga.
wala naman masyado sira. check up lang siguro plus a few minor issues with my car, City 2006:
1. change ATF. (daan muna ako Honda Shaw for the ATF)
2. wheezing/squeaking belt like sound ng aircon. don't know if bearing yung may prob although malamig pa din yung buga
3. metal scratching sound pag inclined yung daan at naka D or R then stepping on brakes. maririnig din yung sound pag iniikot yung steering wheel pag ganito. pero wala sound if naka N.
4. revving up (does not exceed 2krpm) while on Neutral, but not all the time.
5. replace park light.
6. check everything else.
December 5th, 2009 10:53 PM #176
sorry pre, was not able to visit your shop kanina. medyo inumaga ako ng uwi. hindi din kayo open ng sundays diba? try ko pa maghanap ng time ulit.
- Nov 2003
- 3,848
- Sep 2009
- 1
December 8th, 2009 12:37 PM #178Sir how much po bumili and palagay ng shocks for Honda City 1994? Do yo use original parts for that or do you have better alternative brand? Magkanu po estimate nyo for both front and lower arm?
- Nov 2003
- 3,848
December 8th, 2009 12:49 PM #179you can call the shop at the number in my signature for all estimates
- Dec 2009
- 3
December 21st, 2009 11:25 PM #180Sir Migs,
I have a honda esi 93, may problem ako sa rpm kapag tirik ang araw halos mamatay yung engine minsan natutuluyan na mamatay yung engine. Sa gabi naman or kapag hindi mainit di naman masyadong nangyayari lalo na kung d ko gamit yung A/C smooth siya tumakbo.
me humming sound din alternator ko, nagpapalit na ko ng bearing pero bumalik yung sounds after a month, nung binabalik ko sa gumawa palitan ko na lng daw ng bagong alternator. nagpapalit din ba kayo ng bearing ng alternator?
huling tanong ko sir nagkakabit ba kayo ng grounding kit and available po ba sa shop nyo yung kit?
Did you let the motor rest in between? These handheld pumps are not heavy duty.
Need recommendations on tire inflator.
