Results 1 to 10 of 18
- Jul 2007
- 65
May 6th, 2008 11:01 AM #1To any tsikoteers that has this first hand experience,
Appreciate any suggestions, recommendations regarding this.
We are planning to travel (RORO) to Bacolod from Manila next month. A few questions
1. Meron bang direct na RORO from Manila to Bacolod?
2. How much would it cost? Vehicle would either be L200 pick-up or Innova. Di pa alam kung anong sasakyan ang dadalhin.
3. What are the documents needed other than the OR/CR?
Thanks in advance
May 6th, 2008 01:51 PM #2
pls contact super ferry or negros navigation...it is a lot cheaper than driving your car all the way to bacolod from manila.
May 6th, 2008 02:13 PM #3
Walang direct RORO manila to bacoldo. kung gusto mo diretso use negron navigation. siguro mga less than 20thou one way for your L200. last year dinala ko strada using negros mga ganun nagastos ko. Pabalik nag RORO na yung strada. Mga 12thou plus nagastos. Use roro pabalik kasi me sakay na yung pickup na tatlong tao. Prepare lots of copy(xerox) or OR/CR kung RORO ka.
- Jul 2007
- 65
May 6th, 2008 02:54 PM #4Isuzoom, niwde11,
Salamat sa reply. I'll contact superferry and negros navigation to see which has the better deal for us.
Salamat uli,
September 22nd, 2010 01:26 PM #5
I was in Metro Bacolod the last few days (we took the plane though) and I was able to ask around.
From what I've been told, the journey will require at least two RORO ferry trips to get to Bacolod from Manila. As mentioned there is no direct RORO voyage to Bacolod.
The RORO ferry will leave from Batangas, then stop at another port. Sadly I'm not sure if it's Mindoro or somewhere in the Visayas. You will then board another ferry and enter Negros island via Escalante City in the north, which is a RORO port. From there, you can drive to Bacolod City in about 2 hours - passing through Cadiz, Victorias, Talisay and Silay.
HTH!
September 22nd, 2010 11:28 PM #6
Bro, If I were you, try mo mag SRNH. you can leave manila after lunch.
02:00PM Batangas port. Every half an hour ferry leaves for Calapan
05:00PM Arrive Calapan.
09:00PM Roxas port: 2 ferry leaves at 10:00PM and 1 by midnight.
03:00 Caticlan port and drive all the way to Dumangas port.
07:00 Dumangas port. ferry departs by 8.
before 10 nasa Bacolod ka na.
Estimate lang yan pero subok ko na.
Bring 2 photocopy of OR/CR and ilang P20 or P50 (para sa mga alam mo na).
mga total na gastos mo is around 7k max na yun,
sa batangas ka na mag pa full tank para mura.
Sarap mag byahe bro.
hope this helps.
- Jun 2011
- 1
June 3rd, 2011 09:55 AM #7underman,
if i take the roro from batangas to bacolod at and sakay ko nissan cefiro with 5 passengers mga magkano ang babayaran ko one way. sa estimate lang po.
danbeth,
September 27th, 2016 01:34 PM #8
mga sir plano ko rin pong ang Accent ko this December from Batangas to Bacolod. ano po kaya latest update dito?
- Feb 2009
- 15
October 5th, 2016 08:15 PM #9
October 25th, 2016 12:52 AM #10
good. these trucks are taking up too much space they don't fit into normal slots anymore. this...
PH Gov't looking to bring back excise tax for...
