Results 1 to 6 of 6
- Apr 2004
- 75
August 23rd, 2004 10:50 PM #1Some questions about wheels and tires.
On Wheels
Example: 14 by 6
I understand that the diameter of the wheel is 14 inches. But is the "6" the width of the wheel, and is this measured in inches?
On Tires
Example: 195/60/14
I understand that the the tire is for a 14 inch wheel. I also understand that the width, and the tirewall of the tire is 195 and 60 respectively. But is the "195" and "60" measured in mm?
- Jul 2003
- 49
- Apr 2004
- 75
August 23rd, 2004 11:18 PM #3Thanks!
Now I understand why fatter tires seem to have a thicker sidewall than thinner tires, even though they have the same "50 Series" profiles.
How about the wheels? When you say 14 x 6, is the 6 the width, measured in inches?
August 24th, 2004 10:11 AM #4
6 inches is the width. And then there's offset - JJ or E or something. Though di ko pa rin kabisado enough to explain it. I think may tech articles sa www.tirerack.com try mo na lang.
August 24th, 2004 11:14 AM #5
195/60/14
Yung 60 ay yun ratio ng kapal ng sidewall vs the thread width. Kaya you'll see "50 series" tires na iba ang height kung 235 ang width vs 275 ang with.
so 195/60 means that the sidewall is 60% of 195mm
August 24th, 2004 05:07 PM #6Originally posted by the_wildthing
...And then there's offset - JJ or E or something..
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
