Results 1 to 8 of 8
- Jul 2012
- 113
May 2nd, 2013 10:23 AM #1Hi mga gurus,
Ask lang po ulit,
Balak ko kasi bumili ng gulong, meron kilala ko na same size kami, kaso yung sa kanya eh 195/60/14 yung current ko is 185/70/14.
Okay lang ba yun?
Thanks mga gurus.
May 2nd, 2013 10:55 AM #3
gamitin mo eto to help you:
Tire Size Calculator - Tire & Wheel Plus Sizing
better if you know your stock wheel size, then use the said calculator para hindi ka gaano malayo or say sa speedo mo.
- Jul 2012
- 113
May 2nd, 2013 12:10 PM #4
May 2nd, 2013 12:39 PM #5
well, ganito kasi yan - on the red box input your stock wheel/tire size (mine is: 215/60/R17, and i upgraded to 18 with tire profile 235/50) and the blue box yun target mong "upgrade"
so per the wheel calculator, lumalabas na .35% akong "mas mabilis" sa dapat na speed nito (which the gauges are calibrated with the OEM specs)
but at the end of the day, it's your time & money spent for your ride.
- Jul 2012
- 113
May 2nd, 2013 01:12 PM #6Thank you sir..
According to the calculation, the diameter variance is -4.07% for 185/70/14 to 195/60/14.
Tingin mo sir di naman ako magkakaproblema don?
- Jul 2012
- 113
May 2nd, 2013 01:12 PM #7
June 26th, 2013 01:21 AM #8
check mo ito Tire size calculator by miata
based sa calc 1inch difference ng diameter.Last edited by RC-V; June 26th, 2013 at 01:35 AM.
Daming issue ng SU7:grin:
Xiaomi E-Car
