Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Ano effect pag hindi balance ang gulong?
    Maingay? Maalog?
    Maalog steering.
    nanginginig sa manibela pagmabilis na takbo. usually around 80kph above
    Sent from Constantinople
    maingay? may effect din ba kahit sa likod ang hindi balance?
    Kung maingay, baka sa goma na.
    Fwd, OK lang hindi balance likod pero kung naging maalog, pacheck na rin.
    You might get a wiggle especially around 40-60 kph.
    May maingay kasi sa likod... pacheck ko nga kung goma or bearing na.
    naka 17 40s kasi ako at nankang ang gulong.
    Jan 2009
    The vehicle speed at which the oscillation starts happening is not the same for all vehicles. It depends on the amount of imbalance, the dimensions of the tire and how tolerant is your steering mechanism. Some have reported 60kph while some only starts to feel it at 140kph.
    Feb 2012
    Wow! Same problem I was about to ask here.
    Currently I am also experiencing road noise apparently coming from my rear end. Not sure din kung tire o wheel noise ba yun or kung sa bearing na ba. It started lang kasi since I changed to Yokohama A-Drive yata (confirm ko mamaya). It started barely noticeable. Akala ko dati me tricycle na nakasunod sa akin. Now it's getting worse, even as slow as around 40kph nag-start na umingay. Nagtataka lang ako kasi parang wala naman ako narinig na ingay sa harap samantalang same tire din lang naman. Only difference di ko pa ulit napa-balance gulong ko sa likod. When I bought my wheel and tires kasi kasama na wheel balancing. Pero when I got to SLEX grabe ang alog ng manibela from 80kph pa lang. So pinare-balance ko at naging swabe na. Sa likod same worse balance pa rin. I am thinking to change my rear tires to another brand or another model, pero baka kasi di pa rin ma-resolve. Sayang kasi relatively bagong-bago pa mga tires ko.
    Dec 2009
    Guys ask ko lang. Pag nag tire rotation ba kailangan pang i wheel balancing?
    Posted via Tsikot Mobile App
    Jan 2009
    When wheel balance is off, you don't usually hear anything... you feel it as an oscillation.
    If you hear a continuous drone from any of the four corners that increase in frequency and intensity as you gain speed, it's likely caused by faulty wheel bearings.
    isa pang magiging effect ay di magiging pantay upod ng gulong
    Quote Originally Posted by CLAVEL3699 View Post
    Pacheck na rin sa balancer lahat. Baka oblong yung tires or worse, mags.
    Ingay usually sa luma na kasi goma or the type of tire that was put on. Kung malalaki threads ng goma, usually maingay talaga.
    Bago yung tires bro... Malalaki ang thread nya V shape pa.
    OO nga pag oblong maingay nga sya katulad nung sa altis ko nung pinalitan yung gulong nawala ang ingay.
    Sep 2012
    Quote Originally Posted by gearhead000 View Post
    Ipa diretso mo na sa camber correction and wheel alignment. May mga sasakyan na may adjuster sa likod na kailangan din i align same as front pa check mo na rin
    Kung 4 na goma bago tapos likod lang maingay baka wheel bearing. Best way to check is lipat yung front tires to the back then kung maingay pa rin, pacheck na wheel bearing.
    ako lang ba namamahalan sa wheel balancing lol
    1k din inabot nung nagpalit ako ng gulong tapos pina balance ko. Sa iba ko nabili yung gulong at hindi doon sa shop na nagpa balance ako.
    Since experiencing RoadForce balancing, it's that or nothing. The lone 1 here charges P200 a corner + weights.
    2 tires lang ito bro
    naiinis lang ako kasi di ba may weight na kasama mismo sa tire. tinanggal tapos nilipat lang, pero sinama sa bilang [emoji1787]
wheel balancing...
