Results 1 to 2 of 2
    Feb 2017
    Anong filler o putty po ang ginagamit? Any specific brand po and saan nabibili?
    Anong grit po ng sand paper ang gagamitin?
    Bat parang walang nag ddiy ng repair ng curb rashes dito? Mas mura ba kung bibili nalang ng bago? Hehehe
    Aug 2017
    Quote Originally Posted by danegoesonline View Post
    Because painting requires a lot of skills... Applying fillers, sanding, painting are 3 different skills.
    Fillers : a) Heavy fillers, I use Polytuff followed by b) light (green) putty.
    Sanding : normally.,use 3 different grits, heavy grut 60, medium grit 120, finishing grit 2k...as prep before painting... After painting, more sanding... Sa grits... 1k, 2k, 3k grit. You know how to dry and wet sand?
    Painting : a) Primer b) Base coat c) Color coat d) Top coat... In between these .... A lot of sanding
    Sometimes you need to use a mix of aluminum powder + mighty bond for deep gutter marks
    And you'll need a lot of time and patience
    I only DIY my expensive mags
DIY. Repairing of curb rashes on wheels
