Results 1 to 15 of 15
    Apr 2018
    hello mga ka-tsikot, just got an OEM fiesta mags for my ecosport pero hindi pala sukat so i have it re-stud from 100pcd to 108pcd, any expert input is highly appreciated, TIA!
    Quote Originally Posted by Solitaire View Post
    may pics ka bro? di pako nakakakita nyan eh
    Apr 2018
    hindi ko napicturan bro bago ilagay, ang paliwanag sa akin ay ifi-fill in daw nila ung butas ng alloy, patitigasin tsaka bubutasan ayon sa pattern na akma sa pcd na kailangan, nakita ko bago isalpak ay may parang metal insert ung mga butas...
    i have seen alloys, with two sets of bolt holes.
    perhaps this is the better thing to do, instead of filling it in and re-holing.
    the shop should be able to guide you, kung puede at kung safe.
    good luck.
    Feb 2009
    The aesthetic value of your car is not worth compromising your safety or the safety of the other motorists. Use the correct bolt pattern. As a matter of fact, use only JIS, CSA or US DOT standard wheels. If you can, use the same offset and same width to maintain the same scrub radius. Negative offsets shortens the life of the bearings or outer bearings and shortens the service life of the steering components in addition to a less stable vehicle handling.
    Jul 2013
    I agree with the posts above. It's NOT safe...
    But I've seen/done/used ones before...
    So I guess it all depends on your budget and luck.
    ***I've tried punching new holes to the wheels... And changing the holes of the car. Student pa ako noon, have to play with the budget I have.
    Nov 2011
    Imho hindi yan safe like yung mga PCD converters...
    Just sell it back and get another compatible mags.
    Mar 2004
    That's dangerous ... buy proper fit/sized wheels ...
    Quote Originally Posted by TheUninvited View Post
    pcd converter seems safe enough for everyday use, provided he does something like 1000k KM check. plus use products like threadlock. pero risky nga yung gusto ni TS. parang mas matibay pa ang welded eh.
    Don't. Your wheels are the things connecting your car to the road. Do you really wanna risk it?
    Dec 2009
    Bad idea, it puts your life at risk
    Put more value to your life
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Feb 2014
    ok lang ang risk kung sarili mo lang ang affected. problem is it's a public road
    and those are just stock fiesta wheels not some unobtanium vibranium wheels
    Apr 2018
    ok guys, balik stock ako, thanks for all your inputs
rim re-stud/re-bore
