Results 1 to 8 of 8
- Jul 2011
- 27
October 22nd, 2011 12:39 AM #1been planning to change my lug nuts mga ser,
1. whats the difference between the alluminum ones vs the metal ones? does it has something to do with rusting?yun po bang lug nuts tlga yung nag ra-rust or yung stud bolt yun?
2. the difference between the short lugnuts vs long or extended lugnuts?
3. difference between colored vs chrome/stainless lugnuts? (do the colored ones fade due to long use or being old nuts)
recommend p0 kau or comment..
thanks tsikoteers!
[i have the same topic at brakes,steering, wheels,suspension, pa delete nlng kung saan po yung wrong section]
October 22nd, 2011 01:26 AM #2
aluminum lugnuts don't last very long. Aluminum is soft so using aluminum lugnuts will just result in stripped threads sooner than later. Also aluminum expands more than steel when heated. This will result in the aluminum lugnuts working their way loose simply with the heating/cooling cycle of your wheels which is unsafe.
- Jul 2011
- 27
October 22nd, 2011 08:30 AM #3
- Jul 2011
- 27
October 22nd, 2011 10:36 AM #4
October 22nd, 2011 11:14 PM #5
- Jul 2011
- 27
November 1st, 2011 02:56 AM #6
- Feb 2011
- 20
November 3rd, 2011 11:13 AM #7alums vs metals? alums are lighter
rusting? nah, lighter alums are race intended
avoid open ended lugnuts, alums or non, they re prone to rusting.
November 3rd, 2011 12:41 PM #8
If the lugnut is of good quality, even aluminum ones can last a long time. I've had my (original) aluminum ones for three years and several trips to the vulcanizing shops and several more trips to the tire shops for alignment later, they're still tight.
If they're of bad quality... I've had cheapo lugnuts rust and strip within a year.
With aluminum, the important thing to remember is to not overtorque the lugnuts to avoid stripping them. And yes, avoid the open-ended ones, as those go out of round too easily, aluminum or steel.
Buhay na buhay ang BGC this evening. Bukas halos lahat ng restaurants. Sabi pa nung isang cashier...
Traffic!
